And its back..... sort of
Old Jul 19, 2012 | 09:36 PM
F450 Aaron's Avatar
F450 Aaron
So recently had a badly leaking EBPV. Which I deleted, new outlet, new pedestal. Today I got in a bind getting on the highway and had to get on it pretty hard, everything seemed fine. Got out of my doctors office and look as I am approaching the truck to see a patch of oil about 8x8" under the drain hole in the inspection plate. Opened the hood and yep there is oil, start looking over everything, HPX connections are clean, pedestal is clean, HPOP lines are dry, everything seems normal. Checked the oil and it was a little low, drove home and left her running opened the hood and can't find anything that seems to be leaking. After sitting while running there is about a dollar sized amount of oil.
Any ideas on other things to check? Is it possible to see the HPOP non serviceable plug while it is in the truck? Where is it located on the HPOP?
Old Jul 19, 2012 | 09:46 PM
BigAlsPSD's Avatar
BigAlsPSD
Clean up the valley really well, and then see if you can find the leak.
The HPOP non-serviceable plug has to be replaced with the HPOP out.
Here's the instructions.
http://www.dieselorings.com/docs/service_plug.pdf
brian42
16
Feb 6, 2017 10:05 PM
badluck b
16
Jan 4, 2013 07:00 AM
Deerslayinrenek
Apr 12, 2011 11:15 PM
RNH Performance
19
Mar 30, 2010 02:01 PM
jferrar5
Jun 14, 2007 06:43 AM
