Ticking noise
Old Jul 19, 2012 | 08:05 PM
wader250's Avatar
wader250
Ticking noise
Got home from work this morning and noticed when I pulled in the drive and opened the door a ticking noise coming from under truck. Finally had time this evening to crawl under truck and investigate noise. It's coming from the front of the transmission where it bolts up to engine. It's a pretty much steady tick and goes away for a few seconds here and there. when you increase RPM's it's still there and I think goes away at higher RPM's, it doesn't get louder as you increase RPM's just stays the same level. Any ideas? Anyone else heard this? Will get it to shop Monday hopefully and get this checked out and NoX sensor changed out too.
Old Jul 19, 2012 | 09:18 PM
kper05's Avatar
kper05
Recent oil change?
Fresh oil will cause the engine to tick until there is about 1000 miles on the oil.
Ford said this is normal.
I imagine the older engines had this too but we hear this because the 6.7L is quiet.
The other tick is an active regen but you hear that mid cab.
A regen tick only lasts in about 7 ticks every 30 seconds or so though.
Obviously you could have a different issue but these are the two I hear and what I explained is normal.
Old Jul 19, 2012 | 09:45 PM
wader250's Avatar
wader250
oil change two weeks ago. I just noticed tick today not before, strange!
Old Jul 19, 2012 | 10:04 PM
kper05's Avatar
kper05
Mine doesn't tick right away.
It takes a few hundred miles on the oil.
About 1000 or so later, it eventually goes away.
I notice it most when driving along a fence row with windows down.
Old Jul 20, 2012 | 06:54 AM
Hdslider's Avatar
Hdslider
You know that is odd. I'm very finicky and neither of my 6.7s ticked after oil change.
Maybe some dealers put in different weight oil in them. Causing it. Usually a fresh oil change makes a engine quite and happy.
Old Jul 20, 2012 | 07:31 AM
kper05's Avatar
kper05
Maybe it's motorcraft oil?
I change my own oil and use MC 15W-40.
Old Jul 20, 2012 | 08:12 AM
jack_pine's Avatar
jack_pine
Have heard the tick/oil change thing discussed before.
What, exactly, makes it tick (other than just changed oil)?
Old Jul 20, 2012 | 12:05 PM
stsmark's Avatar
stsmark
There's an info bulletin Ford put out about it, I heard synthetic oil or the Motorcraft additive stops it. Anybody able to verify this?
Old Jul 24, 2012 | 12:37 PM
T for Texas's Avatar
T for Texas
Yeah, I can verify that it still ticks with synthetic. I use Mobil 1.
My latest ticking experience (other than my left eye and right foot ) was today. I had my oil changed (@ 22,700 miles) Friday, and have gone about 500 miles since.
Oh, and mine is a '12.
Old Jul 24, 2012 | 02:19 PM
parkland's Avatar
parkland
Originally Posted by kper05
Recent oil change?
So what exactly is the ticking sound?
Old Jul 24, 2012 | 03:10 PM
stsmark's Avatar
stsmark
Kind of like a collapsed lifter in the old days, but lower in the motor, not up by the valve cover. Mine's there at idle to about 1000 rpm, really noticeable but apparently harmless.
Thanks T for the response.
Old Jul 24, 2012 | 03:29 PM
jack_pine's Avatar
jack_pine
I have been trying to get an answer to that for some time. Have only done one change (synthetic) and did not experience it. What makes it tick (sans oil change)?
Old Jul 24, 2012 | 05:00 PM
kper05's Avatar
kper05
I don't know what mechanical piece causes it.
I tried to record it once but my camera picks up the fan noise over the tick.
One of those higher noises the human ear does a better job at picking up.
Old Jul 24, 2012 | 09:13 PM
FishOnOne's Avatar
FishOnOne
I did my first oil change this weekend at 3500 miles. I changed the oil to Rotella T6 Synthetic and have not noticed this ticking noise.
Here's Ford's response for the ticking noise for the 6.4 psd so I suspect the source of the noise applies to the 6.7 psd as well.
https://www.ford-trucks.com/forums/7...ing-noise.html
Old Jul 24, 2012 | 09:35 PM
cford716's Avatar
cford716
Interesting, I have also noticed it.
