Bed removal
Old Jul 19, 2012 | 12:53 PM
FordYoungGun35's Avatar
FordYoungGun35
Bed removal
Tips or how to remove bed from a 1996 XLT f150 4x4 regular cab short bed
Old Jul 19, 2012 | 02:51 PM
Evan_P's Avatar
Evan_P
Well here is one way. Click it and look through the next few as well.
*Courtesy of Steve83
Old Jul 19, 2012 | 03:06 PM
Diesel_Brad's Avatar
Diesel_Brad
-6 bed bolts(nuts underneath)
-plug for taillights
-3 screws per filler neck + hose clap holding tube to bottom of bed
3 friends to help you pick it up
Old Jul 20, 2012 | 01:00 PM
FordYoungGun35
Those 6 bolts won't budge
Old Jul 20, 2012 | 01:02 PM
Evan_P's Avatar
Evan_P
Start soaking them in penetrating oil. Give them a good day or so of soaking.
Old Jul 20, 2012 | 02:25 PM
Diesel_Brad
Weld a 7/8" nut to the heads. Then have someone hold the nut with a wrench. Then MAN UP and turn the nut from underneath.
Old Jul 20, 2012 | 03:03 PM
FordYoungGun35
There not spinning but I've got 3 off.. The 2 closest to the tailgate and the one behind the passenger side
Old Jul 20, 2012 | 04:20 PM
Diesel_Brad
If you have to put that much effort into breaking them loose, it will tear the sheet metal bed and the bolts will start spinning
Old Jul 20, 2012 | 05:29 PM
FordYoungGun35
Got 6 loose and the one behind the drivers side started spinning with 2 threads left
Old Jul 20, 2012 | 05:46 PM
FordYoungGun35
It's just the 6 bolts then I can lift it off right
Old Jul 20, 2012 | 05:56 PM
Diesel_Brad
filler necks and taillight harness
Old Jul 20, 2012 | 06:05 PM
FordYoungGun35
Okay well how do I remove those? What and where arethe filler necks
Old Jul 20, 2012 | 06:10 PM
Diesel_Brad
Filler necks are what goes between your gas door and the fuel tank. Typically (3) 7mm head screws hold them in when you open the gas door. Then there will be a hose clamp underneath that holds the hose to a lil tab on the bottom of the bed
Old Jul 20, 2012 | 06:12 PM
FordYoungGun35
How do I need to go about removin that so I don't **** anything up
Old Jul 20, 2012 | 06:41 PM
ncranchero's Avatar
ncranchero
Remove them (the 3 7mm screws) from the bed NOT the hose from the tank.
This was actually on my 98 F150 but the bracket/clamp is the same on yours.
