best i6 config???
Old Jul 24, 2012 | 07:32 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Ha! I may have a Predator carb in my hands soon. Found one for cheap, at least compared to what they're flogging them for new and/or on eBay. My cousin is bringing it maybe this week, maybe next. It'll be after the new bathroom's done before I can play with it but couldn't pass it up.
I checked out the Predator website and manual, it's an interesting piece of work. They claim it will work from 390 to 930cfm. It's a squarebore, and by squarebore I mean square bore. There are spring-loaded flaps like the secondaries on an Edelbrock or Q-Jet at the top. No chokes, but the air flap springs are bi-metal. It's apparently easy enough to drill and mount a vacuum port if you need one but I run manifold vacuum anyway.
It looks pretty cool. I remember reading about them in some rod mag when I was a pup back in the '80's but have only seen a couple (from a distance) in real life.
They say to expect a decrease in mileage since it's set to run on the rich side and it will idle between 800-1,000 rpm. 800 is okay with the ZF, maybe at 1,000 the lugging rattle will go away. She idles around 600 rpm with an Edelbrock 500 now.
I just got all the parts to rebuild a little 4100 and this wacky new toy has to fall in my lap.
Old Jul 24, 2012 | 10:17 PM
muscletruck7379's Avatar
muscletruck7379
I have david vizards carb& intake book, and on the predator (which is technically a constant velocity like motorcycles) he explains how they simply have a cam that you can swap out for different fuel curves, i guess you can even get blank cams to file yourself. he says the only downside is some difficulties with fuel distribution.
Old Jul 25, 2012 | 09:04 AM
Harte3's Avatar
Harte3
"...david vizards carb& intake book..." Vizard the Wizard...his Volume One and Volume Two are indispensable to the understanding of performance principles.
Old Jul 25, 2012 | 12:28 PM
mindfunk13's Avatar
mindfunk13
ok, god help me, i have committed to: duel plane offey, 390 holley 4 bbl vac secondaries, electric choke, chev rockers, rv2 cam, headers,dura spark II, lets see what a 300 can really do!!
Old Jul 25, 2012 | 12:43 PM
AbandonedBronco's Avatar
AbandonedBronco
Heh, sounds like fun. Keep us posted on how it goes!
Old Jul 25, 2012 | 01:39 PM
mindfunk13's Avatar
mindfunk13
will do!
Old Jul 25, 2012 | 07:10 PM
BaronVonAutomatc
Drop a little extra coin or put in the effort to port the head while you're at it. Should be a sweet little set-up.
Old Jul 25, 2012 | 09:22 PM
mindfunk13's Avatar
mindfunk13
can anyone fab the water heated intake piece? i wil be happy to compansate them for their time
Old Jul 26, 2012 | 06:23 AM
willowbilly3's Avatar
willowbilly3
sounds like you are on the right track there. That's pretty much my engine except I have a 260H cam, and don't have the intake heat (which I really need). I am running an old Galaxy heated spacer though. also on the Duraspark, I really can't preach enough on using the GM module and EFI coil. That is probably the single best modification I did.
And also the head porting, if you haven't assembled the engine yet, that is a day well spent. I didn't do it on this engine because it was together when I got it but I did it on my 72 and can't say enough good about that.
Old Jul 26, 2012 | 08:56 AM
Harte3's Avatar
Harte3
The choke point for flow in a 240/300 is the head. While add-ons can increase performance a bit, one doesn't get full value for the parts unless the head is ported/polished.
"I really can't preach enough on using the GM module and EFI coil." That's probable the least expensive upgrade there is...JY parts work fine.
Old Jul 26, 2012 | 07:43 PM
BaronVonAutomatc
I bought two 5/8" A/C elbows from Sachse Rod Shop then just found a local welder who happened to have some scrap 1/4" aluminum plate and got him to fab a plate. He charged me $25, IIRC.
Old Jul 27, 2012 | 09:55 AM
1986F150six's Avatar
1986F150six
Looks good and has good fittings for the hoses!
78bigunns
Nov 7, 2025 11:06 PM
juang316
Sep 10, 2013 12:26 PM
nothercrash
20
Jan 3, 2013 08:39 PM
85BRONCOXLT
1978 - 1996 Big Bronco
Nov 27, 2012 10:07 PM
mindfunk13
Jul 19, 2012 12:27 PM
