Low transmission pressure?
Old Jul 17, 2012 | 06:54 PM
redant's Avatar
redant
Hi
I have a 97 2wd F-Super Duty with an E40D trans. I have had trans overheating problems since I owned the vehicle. The trans will overheat under no load and just around town and mostly highway speeds. The other day it overheated when getting off the highway. Fluid is now coming from the bellhousing at a study rate. The fluid was so hot it was sizzling but the cooling lines leading to the radiator and the auxilary cooler did not feel hot. Just warm. Any chance the cooling system is not recieving enough pressure to cool the fluid? The system was recently flushed so I assume the system is not clogged. Suggestions?
Old Jul 17, 2012 | 07:03 PM
Action4478's Avatar
Action4478
Unhook both of the lines & carefully blow some air through the lines to see if there is a blockage...
Old Jul 18, 2012 | 10:28 AM
redant's Avatar
redant
Ok I'll do that. If a blockage was not the issue, what could be responsible for low pressure? I am pulling the trans today due to that blown front seal. Also, a large amount of fluid is able to drain from the front seal. Because of this, the transmission has no function at all. Does this sound normal? I really dont want to replace this trans.
Old Jul 18, 2012 | 11:02 AM
blageurt's Avatar
blageurt
You need to Scan it for codes ... could be the EPC solenoid in the solenoid pack .... P1745 or P1746 would indicate that.....
Old Jul 18, 2012 | 02:06 PM
redant's Avatar
redant
I came up with no codes with an OBD2 scanner. However the "off" light on the column shifter has been blinking. I have never been able to pull a code from that blinking light.
Old Jul 18, 2012 | 02:18 PM
blageurt's Avatar
blageurt
If the light is blinking you have a code.....you need a good scanner to read PSD codes....Like a Snap-on MT 2500 or AE or Autotap Diagnostic like I have......a regular cheapo scanner will not read the codes ....I suggest you find out what the codes are before you remove the tranny......
Old Jul 18, 2012 | 08:04 PM
redant's Avatar
redant
Shoot, how am I gunna get one of those. I already pulled the tranny. Wonder if I can still get those codes...
Old Jul 18, 2012 | 08:12 PM
redant's Avatar
redant
Is the tranny expected to have zero activity in it if that front seal was leaking excessively?
Old Jul 18, 2012 | 08:49 PM
blageurt's Avatar
blageurt
The front leak can be due to overheating ...like what happened to me
Old Jul 18, 2012 | 09:11 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, once the fluid level drops enough.
The codes will still be in memory of the computer after the transmission has been removed IF you didn't disconnect the batteries.
Old Jul 18, 2012 | 09:16 PM
fordpride's Avatar
fordpride
Mark with the MLPS unplugged will it throw unrelated codes ?
Old Jul 19, 2012 | 02:22 AM
redant's Avatar
redant
Im sure it will throw unrelated codes but I just need what is in memory. Had a quick look inside the tranny (only the overdrive clutches) and so far so good. Now im going to seal up the pump and hopefully get her back in tomorrow. Still a question on the no activity thing. The front seal was leaking substantially. I checked the fluid level and topped it off to attempt to move the truck. Still zero activity with it filled. Normal?
Old Jul 19, 2012 | 01:25 PM
redant's Avatar
redant
E40D pump (apart)
This is my pump (apart) from my E40D. That bushing definitely needs to be replaced. That bushing scarred the T.C. Is that ok or what needs to be done? Also, I found metal shards in two of the ports in the pump. The shards are revealed on the zoomed images; outside most port in the pump, bottom and top sides of the images, and the dark circular feature toward the left and right center of the zoomed images. Any knowledge of the shards source?
Old Jul 19, 2012 | 02:07 PM
Mark Kovalsky
If the trans is out you will get a bunch of electrical fault codes. Every solenoid, the MLPS, and the temp sensor.
If the torque converter is scarred where the seal rides you need a new converter. The old one will leak no matter how good the seal is.
Old Jul 19, 2012 | 03:00 PM
redant's Avatar
redant
How about where the bushing rides on the T.C.?
