Here's a list of some of the ScanGauge codes with the values for each one. EGT isn't there, that's somewhat a matter of opinion and where you install the probe for the gauge.
Sg2 codes w/values
Here is a partial list of Xgauges with Ford's values.
KO=KEY ON LI=LOW IDLE HI=eHIGH IDLE OR=OPERATING RANGE
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced. Check when cold
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
EGR Valve Position (mm)
TXD: 07E022096A
RXF: 04620509066A
RXD: 3010
MTH: 000100010000
NAM: EVP
Note: EGR Valve Position in hundredths of a millimeter, where 0 mm indicates a closed EGR valve position.
EGR Valve Position Measured (%)
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000qq
NAM: EVM
Note: MEASURED EGR Valve Position, in %, where a low value indicates a closed EGR valve (0 EGR flow), and a high value indicates an open EGR valve.
Here is another BAR if the above one is not working for you. The one below works for me.
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
Okay thanks guys.
So as far as temps for eot, ect, tranny and egt what should they be around, so I know what I should be looking at if\when I get them installed?
Awesome, that's exactly what I was looking for. So for the gauges, will eot ect tranny egt gauges be a good combination to get? Or is there any I should swap out for another?
I am propably going to do both. So far I have the SG2 (most bang for the buck) I will probably do a triple pod with Fuel Pressure, Oil Pressure, and either a pyrometer checking manifold temp or a EGT (those where picked because they are guages that are usefull but compliment the SG2 (ie no duplicates). But that is dreams for another day. Right now I am still working on the assumption that my previous owner did nothing.... so installing blue spring kit and cleaning egr valve this weekend and the modified fuel drain. So catching up on mainternance.
Any benefits between oil pressure gauge vs. oil temp gauge, say in the event of troubleshooting or finding a problem before it starts to be a huge problem?
The sg2 has a oil temp guage so wasn't planning on that. I was looking at either a LP oil or HP oil.... prefereably HP oil but the indicator on the dash of my 04 is just a dummy light so may go with LP oil. You need low pressure oil to supply HP oil to fire the injectiors. So usefull info to have for the truck.
It's really your call. I have a large list of things programmed in my SG2 but I can only monitor 4 of them at any one time. I normally watch Voltage, EOT, ECT and BST. However if during towing or for some other reason you want to free those 2 slots up go ahead and get ECT and EOT. For me I will probably try to concentrate on guages and indicators that I don't already have but it is really personal choice. About the only thing that is a must is fuel pressure.... it is also the one thing the SG2 doesn't have.
