Hello i need help with location of wire for buck up gear, what i need is to connect my rear view camera and i just dont know where to look and where to connect it to make it work when i put reverse gear in my truck i own 05 ford e-150 thank you guys
I just tapped into mine at the taillight for the auto switching. Ran power to the camera full time to so i can use it going down the road to keep an eye on my trailer.
I just check mine pioneer manual and actualy one cable from camera i have to connect to battery second to negative and one is connection like rca so it will go to unit, then from my pionner unit it is direct cable witch i have to connect to rear light ( when you pu the car in to reverse ) will activate rear view automaticly in unit, but my question is if i can find this cable closer to the front ( from rear buck up light ) or i have to run all the way from back to the front ? it will be easier to find something on front and btw i finish my ride so i add couple pictures in my album i have to check how to add picture on web actualy and ask what you guys think ....
So i just install my rear view camera and it works great thank you for great info about that wire on kick panel it was way much easier to connect it there then go all the way from the back of my van. Thank you
