runs rough
Old Jul 16, 2012 | 06:04 PM
babs2972's Avatar
babs2972
oooh in that case I would change my fuel filters first, if you have over 10,000 miles on them of good fuel. Again stay away from the dealer. About $80 for both filters at the dealer and I get mine right from the local international dealer for $37. bpounds gives awesome advice also!
Old Jul 16, 2012 | 06:22 PM
tlc3810's Avatar
tlc3810
If I recall it ran rough even when warmed up. I just remember it started up without hesitation but then quickly becomes rough but drives normal. My neighbor saw me dinking with it satrday night and said he didn't even notice it was running funny. Just giving an example of how minor the rough is
Old Jul 16, 2012 | 06:38 PM
bpounds's Avatar
bpounds
Okay, so it is very minor, and possibly when hot or cold.
I would check that FICM first.
If that checks okay, then I would change the oil to a 5W/40. Recommend Rotella T6 from Walmart. See what happens.
Next I would try some Rev-X oil treatment. See what happens.
Those are all things you can do yourself inexpensively.
BTW, is your coolant level holding where it should be?
Old Jul 16, 2012 | 07:31 PM
tlc3810's Avatar
tlc3810
I didn't even think to check the coolant the last oil change about a month and a have ago all fluids looked good. I will check again
Old Jul 16, 2012 | 07:46 PM
bpounds's Avatar
bpounds
That's not likely the problem, but it is something to eliminate.
Old Jul 17, 2012 | 05:56 AM
karthauler1's Avatar
karthauler1
been reading and im having similar issue, but i only get rough idle first start up in AM i live in FL, clears up and is smooth rest of the day, but that first 10-15minute driving really has no power.. after that pulls fine. sorry to ask in your tread just seems to be similar problem im having
Old Jul 17, 2012 | 06:55 AM
MC5C's Avatar
MC5C
Low fuel pressure sure caused my rough idle problem, of course it did so after it took out one of the injectors. I am in the camp that says you need the blue spring upgrade, it's not an option or put it off till later. Of course, that's because mine cost the dealer over $5K to fix, at the end of the day...
Brian
Old Jul 17, 2012 | 07:06 AM
karthauler1
i did the blue spring last week, was leaking.. not sure if that hurt injector, but can injector be bad in morning and haul *** 15min later?
Old Jul 17, 2012 | 07:08 AM
bismic's Avatar
bismic
Read up on injector "stiction".
Make sure your oil is clean and I would recommend a 5W40 synthetic oil. Even then you might have to try an additive (Archoil or Rev-X). After that, it could be time to replace an injector.
Old Jul 17, 2012 | 07:44 AM
karthauler1
stiction is deff what im going thru thanks ill try some things out
wolfy15
Apr 2, 2019 12:58 PM
seville009
Jan 6, 2016 05:13 AM
rustyroll
Jan 2, 2013 11:07 PM
shad9876
Jan 1, 2008 10:59 AM
jwey
Nov 4, 2005 08:40 PM
