Problem with Trans Position Sensor/P0708 Code
Old Jul 15, 2012 | 08:07 PM
Uthinkso's Avatar
Uthinkso
I scanned my truck last week and it gave me a P0708 code. I looked up the part and ordered the new Ford Motorcraft trans position sensor, but I am having issues removing the old one.
I made sure the vehicle was secure on jack stands and such. Put the truck in neutral and removed the two 8mm bolts. I un-plugged the electrical connector and attempted to slide off, but it was pretty stubborn. I can see the linkage above the sensor and can see that it doesn't connect to the trans sensor. My question is simply this, do I need to just use WD40 and pry it off patiently or am I missing a fastener somewhere?
Any information is appreciated. I have combed the forums and haven't been able to find an answer so I posted here.
Old Jul 16, 2012 | 07:28 AM
projectSHO89's Avatar
projectSHO89
You also have to disconnect the cable from the lever, then remove the lever from its shaft (one nut).
cylemik
Oct 21, 2011 09:58 AM
Rafi69
Jul 12, 2011 01:11 PM
m50
Feb 11, 2011 05:45 PM
bdunegan
13
Jun 13, 2010 10:18 PM
