injector pump ??
Old Jul 15, 2012 | 03:56 PM
40dog's Avatar
40dog
injector pump ??
on the drivers side of the injector pump is a vertically mounted arm which depresses a small rod in and out of the pump. the injector pump on my engine had a broken arm on the bottom and the pin had come out of the hole in the hex nut . So i swapped a arm off another pomp and replaced the pin/rod from another pump .What dose the arm meter when pressing the pin in and out of the hex-nut . the bottom of the arm has a small Allen screw in it to allow some sort of adjustment to this assembly.What is it all for?
Old Jul 15, 2012 | 04:41 PM
NMB2's Avatar
NMB2
its the advance system.
Old Jul 15, 2012 | 05:00 PM
40dog's Avatar
40dog
ok then what is the suggested adjustment for the advance arm set screw.And what would miss adjustment of this arm and screw do to the engine running performance.Since the arm was replaced with another from one of my donor injector pump i would believe the set adjustment is off.
40dog
Jul 27, 2012 07:17 PM
JoeHarbourJets
Aug 21, 2011 09:08 AM
late70sfordnut
Mar 30, 2008 08:45 PM
xjvince
Apr 1, 2007 04:34 PM
