injector pump arm
Old Mar 29, 2008 | 09:49 PM
late70sfordnut's Avatar
late70sfordnut
injector pump arm
89 f250 diesel wouldnt start got to looking there is fuel on the intake , a little dowel pin, and a clip, looking a little closer the arm on the injector pump is broke offand the feul is coming out the hole where the dowel come from can i just replace the broken arm replace the dowel or do i have to replace the i-pump
Old Mar 29, 2008 | 10:21 PM
gumboluvr's Avatar
gumboluvr
Is the arm on the drivers side of the pump? Sounds like the the timing advance arm is broken off and the pin came out. If that is the case, you will have to replace the IP. I wish you the best.
Old Mar 29, 2008 | 10:53 PM
PLC7.3's Avatar
PLC7.3
The arm is only retained in position by the pin holding it in the two small ears on the side of the IP....... are they what you say is broken. If it is the arm broken in two then you should be able to have a shop replace it..........
Old Mar 30, 2008 | 08:45 PM
late70sfordnut
the bottom of the arm is broke off -when you turn the motor over fuel runs out on the intake and yes the arm is on the drivers side of the pump
palehorse13
Sep 23, 2012 04:27 PM
4wheelex
Dec 17, 2010 10:45 PM
FoMoCo390
Aug 23, 2009 06:54 AM
ballyhoo
Mar 18, 2008 09:04 PM
1SG
13
Oct 10, 2003 10:18 AM
