uvch testing please help
Old Jul 14, 2012 | 10:56 AM
horizontal's Avatar
horizontal
Hi,,fairly new here and trying to pinpoint some promblems...I unplugged the connector on the driver side valve cover and Im counting 9 [male ] pins,,is this where I test with multimeter and does truck have to be on,running or what...sorry for ignorant questions,but just want to get it right...also what do I set my meter on..2,20,200 ? if someoneone can help...thank you so much
Old Jul 14, 2012 | 10:59 AM
F350-6's Avatar
F350-6
Yes, that is where you test the pins. The 9 male prongs exposed in the valve cover gasket. I don't know what meter you have, but you could probably set it on 20 and be fine.
Old Jul 14, 2012 | 11:00 AM
mongo75's Avatar
mongo75
IIRC, it goes GP,GP,Inj,Inj,ground,Inj,Inj,GP,GP. Can't rememeber what values you're looking for though. I'm sure someone will chime in with what ou need....
Old Jul 14, 2012 | 11:02 AM
horizontal's Avatar
horizontal
thks sir,you have been a blessing of help ..also does ignition have to be on?
Old Jul 14, 2012 | 11:04 AM
mongo75's Avatar
mongo75
No, you're looking for a certain resistance value that would show if the injector solenoid is stuck open, or if the GP is burned out. WHat kinda problem are you having?
JMP E350
44
Sep 21, 2015 09:02 PM
omanalansan
Aug 21, 2011 08:06 AM
jgilrfr
18
Sep 19, 2010 10:00 PM
ftowelding
Oct 21, 2007 03:23 PM
Whisperinghorse
Oct 6, 2007 12:39 PM
