Valve cover Ohm Test
Old Oct 5, 2007 | 12:41 PM
Whisperinghorse's Avatar
Whisperinghorse
Arrow Valve cover Ohm Test
I'm going to test the valve cover plugs and I need to know what I'm looking for as far as a reading goes and which turminals to test. Can anyone help?
Old Oct 5, 2007 | 12:53 PM
Cuda_jim's Avatar
Cuda_jim
Take a look here: Nice picts
http://andersonimprovements.com/hobb...sandrelay.html
Old Oct 5, 2007 | 12:59 PM
tjbeggs's Avatar
tjbeggs
Nice link! saved for later!
Old Oct 5, 2007 | 03:35 PM
Whisperinghorse
Talking
Ok! and how about the injector connections? Thanks for for the quick reply!
Old Oct 5, 2007 | 05:20 PM
Neal 97 250's Avatar
Neal 97 250
The injectors are the #2 and #4 on each plug
Old Oct 5, 2007 | 06:33 PM
Cuda_jim's Avatar
Cuda_jim
G I C I G
G= glowplug
I= injector
C= common or ground.
When checking the GPs do not use the ground pin in the connector. The reading will be higher due to going through the wireing. USe an engine ground. When check GPs though the connector Anything higher than 10 ohms the GP is getting weak. IF you check the GP directly 3-5 ohms is good, anythiong higher the GP is getting weak.
There is no ohm test per se for the injectors. You would need to do a buzz test.
Old Oct 6, 2007 | 11:19 AM
Whisperinghorse
I've had a miss going on during acceleration and I've already cleaned and replaced the IPR seals so I guess I'll pull the valve covers and check the wiring
Old Oct 6, 2007 | 12:39 PM
tjbeggs's Avatar
tjbeggs
if you ohm out the injectors using the injector pin and the center pin (common) you should have no more than 3.5 ohms. anything more and you have a connector, wiring or solenoid issue.
