Sponsored by: Real Truck
an AC question
Old Jul 13, 2012 | 01:25 PM
tjc transport's Avatar
tjc transport
i ain't rite
an AC question
i posted this in the heating and cooling forum, and only got one response telling me my system needed to be properly evacuated and recharged by a professional after changing out the receiver drier, expansion valve, and orifice tube..
since i know how ac systems work, and do my own ac work, it is obvious i am not paying any attention to that post.
truck is an 02 superduty diesel.
low side pressure is 35 psi, high side is 174 at 82 degrees outside air temp.
dash vent temp is 53 degrees at idle on max air. bring idle up to 1500 and vent temp drops to 48-50 degrees.
take it out on the road at 45 mph and vent temp drops to 44-46 degrees. this sounds like a bad fan clutch, rite?
Old Jul 13, 2012 | 01:45 PM
a12play12's Avatar
a12play12
Im going with low refrigerant charge. 174 high side is actually low for a 134 system. And increasing the RPM increases compressor speed as well as fan speed. But if the fan was bad, both high and low pressures would be high at idle.
just my .02
Good Luck!
Old Jul 13, 2012 | 02:35 PM
Kajtek1's Avatar
Kajtek1
I would ditto low refrigerant. How the pressure looks at 2000 rpm?
Than there is more to clima system that AC. I was surprised to find out that our SD have no heater valve and the core is hot all the time. Slight air leak on the mixer door, the door malfunction and the AC is no match for heater output.
I have valve installed.
Old Jul 13, 2012 | 02:40 PM
tjc transport
i ain't rite
the book calls for 42 ounces, that is what i put in it.
Old Jul 13, 2012 | 03:41 PM
a12play12's Avatar
a12play12
The book also states that you have to add refrgerant oil to the system for each part replaced. As well as evacuating the system to remove all moisture. both of these could also be contributing to your symptom. find the specs for the proper oil charge and do a complete evac and charge with oil. Is 42oz the minimum or maximum charge?? Out here in the dry desert we have to charge to minimum for best performance, Under minimum on some imports. If there is humidity, and cooler temps (under 100) you may have to put the charge to the maximum.
Old Jul 13, 2012 | 04:13 PM
tjc transport
i ain't rite
the system was evacuated and charged last year. it worked fine at close to the same pressures. last year i had 42 to 44 degrees at idle, and would get temps in the high 30's while driving.
dmueller71
30
Jul 10, 2019 09:15 PM
getulus
Jul 23, 2013 08:13 AM
89ford73
37
Jan 7, 2013 10:01 AM
Hibrass
Jul 26, 2005 08:49 AM
golfboy17
Jun 22, 2005 01:47 PM
