Shocks
Old Jul 12, 2012 | 10:21 PM
REA8758's Avatar
REA8758
Shocks
I am new at this the forum thing and the computer thing so bare with me.
I have a 1997 f250HD crew cab with 280K+ miles on it. MY lovely son slug it around the tree in the driveway and screwed the frame up. I have got it fixed the frame. I was wondering some good shocks for it. I got some 350 springs to replace the ones that were broke. what are some suggestions for some shocks.
Something heavy duty applications
Monroe 34964 Gas-Magnum Shock Absorber?
GVW 10K LBS
Thanks guys in advance.
My son said this is the best and most knowledgeable forum out there.
Old Jul 12, 2012 | 10:30 PM
fordpride's Avatar
fordpride
If you wanna spend the cash go with bilstein shocks
Old Jul 12, 2012 | 10:31 PM
fordpride's Avatar
fordpride
Oh welcome to FTE!
Old Jul 12, 2012 | 11:06 PM
madpogue's Avatar
madpogue
So you put springs for a Dana 60 on the Dana 50? From everything I've read, it won't ride right. Those springs aren't arched right for the height of the 50, and they're not set up to twist/torsion laterally with the pivoting action of the traction beams of the D50 front end.
Old Jul 13, 2012 | 11:28 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
If it is rear springs, no problem swapping. IF front, not so good. The 350 springs may actually be to soft for it. Plus they have a positive arch, U shape, so that will push the axels farther from the wheel wells and probably cause camber problems. Make the top side sidewall of the tire over hang the bottom side sidewall. be like having a really heavy load in the very back of the bed that would make the front of the truck lift up.
Old Jul 13, 2012 | 11:46 AM
Talyn's Avatar
Talyn
The 250 springs are actually heavier than the 350 springs.
You are correct on this.
The truck will not ride right in the front with 350 springs on a TTB.
Old Jul 15, 2012 | 05:36 PM
REA8758's Avatar
REA8758
Thanks guys.
What should I do about the front springs at this point? The old ones are done after the wreck.
BearFootCustom
Dec 12, 2012 11:56 AM
MattinEugene
Oct 7, 2010 11:06 PM
turboboost
Aug 31, 2009 11:20 PM
oh2bnok
Aerostar
Apr 14, 2007 03:07 PM
seantx
1983 - 2012 Ranger & B-Series
13
Jan 19, 2005 12:16 AM
