What are these called?
Old Jul 11, 2012 | 03:08 PM
buckin69bronco's Avatar
buckin69bronco
Be careful with that rivnut tool. That thing is relying on the threads of the rivnut to cinch itself up. A better way is to hold the bolt that threads into the rivnut and then tighten a nut down on the bolt you are holding (using washers between the rivnut and the nut you are tightening to reduce friction). It is a PAIN in the butt to strip out the threads of the rivnut. The rivnut is soft so it can cinch up and therefore it’s threads are fairly soft too.
Old Jul 11, 2012 | 06:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by thatsrealnice
382167-S36 .. is the part # for the rivnuts I was asking about earlier
Standard (hardware) parts: Pics in parts catalogs don't always show the complete suffix:
382167-S36 .. Nut-Round Head-Rivet Type / #8 -32 / Obsolete
BOWMAN SALES & SERVICE in Bowman ND has 10 = 701-523-3257.
FREESE MOTORS in Monticello IA has 40 = 319-465-3541.
GREEN SALES CO. in Cincinnati OH has 115 = 800-5443-4959.
Old Jul 18, 2012 | 07:42 PM
thatsrealnice's Avatar
thatsrealnice
I was cleaning my "new" hornbar I got on eBay, and I didn't realize the little Ford oval thing had posts on the back. I broke off the posts when removing, and am going to try to superglue them and see if it holds. Does anyone know if these are available somewhere?
Old Jul 19, 2012 | 05:38 AM
NumberDummy
Horn pad: Black camera case finish or burled 'walnut?' With or without Speed Control?
Look on the backside of the emblem, see if there's any numbers moulded into it.
Old Jul 19, 2012 | 10:14 AM
thatsrealnice
There aren't any numbers on the emblem. It's the "burled" walnut over aluminum insert, and without speed control.
Old Jul 19, 2012 | 11:30 AM
NumberDummy
Emblem not available by itself, only furnished with the horn pad.
EOTZ-13A805-D (replaced D8TZ-13A805-C) .. Horn Pad-Burled Walnut Wood grained finish / Use without Speed Control / Obsolete
Applications: 1978/86 F100/350, Bronco & Econoline.
JST AUTOMOTIVE in Lebanon TN has 1 = 615-443-3086.
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
WESLEY OBSOLETE PARTS in Liberty KY has 10 = 606-787-5293.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 10 = 800-476-9653.
Old Jul 19, 2012 | 11:52 AM
thatsrealnice
Okay, thank you. I'll have to keep an eye out at the pull and pays until I can throw down the coin for one of the NOS units.
white-horse
Massachusetts Chapter
Apr 12, 2013 02:12 PM
collinft
Oct 31, 2011 08:36 PM
97FRD1TN
Mar 17, 2011 05:23 PM
ajordan193
Mar 16, 2007 02:56 PM
zzjonze
Mar 6, 2006 02:54 PM
