I used my stock springs in the rear with a block, you CAN use SD springs in the rear...I just couldnt afford it
Originally Posted by burton7.3
Ok thanks do you have to drill the rear shackle out for the large bolts
Superduty springs fit no problem.
Yes the rear shackle needs to be drilled. As its only the 2 side plates, its a piece of cake to drill. It is a pretty good sized bolt (don't remember exactly) I think I used one of those step drills to do it, otherwise you need a pretty big bit. I'm trying to remember if I had to drill out the front mount, honestly I can't remember.
I know the SD springs in the front have one side that has a really big bolt as well. Curiously, its not the same on both ends though.
If I recall, the SD springs are the same height as the stock springs, but they do ride better (or maybe my 22+ year old springs were shot...). At some point I should put some blocks under there and level out the back of my truck... but thats another story.
Im defently gonna have to do SD springs in the rear pretty soon, my stock rears are pretty well shot I think. It honestly rides pretty bad, the rear that is. The front V codes ride like my dads 2001 super duty, obviously. For the rear, Im guessing 99-04 springs will work? Or are the 05-12 rear leafs the same? I, thinking they made a change somewhere along the line
Before and after pics tommorow if I can get some daylight around work to take the dang things lol
