7.3 Excursion most miles
Old Jun 10, 2016 | 10:28 PM
  #31
Stilllookin's Avatar
Stilllookin
Rolled 250,000 yesterday on my 2002 Limited 4x4. Injectors and glow plugs done once at 190k and a fuel bowl rebuild (i did) and that's about it per all the records dating back to new. Oil changed every 5k. The 4R100 tranny & converter is original and surprisingly still going but I hold my breath and take it easy on her considering I run a Hypertech tuner in level 1 and tow with it all the time.
Old Jun 11, 2016 | 05:33 AM
  #32
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Originally Posted by Jmatthews
I'm at about 165,000.
247k now..........
Old Jun 11, 2016 | 09:38 AM
  #33
7.3Excursion4x4's Avatar
7.3Excursion4x4
My factory tranny / torque converter made it 361,800 miles before going out. I know I'm one of the few lucky ones but I have crazy OCD when it comes to maintenance. At every other oil change (10,000 miles) I would drain the pan and refill. I never had the entire system flushed. In addition to the DieselSite external tranny filter, I've run nothing but Amsoil in it since 59,000 miles when I bought the Ex. I also tow a 13,000# boat and 10,000# Travel trailer all the time. I even beat the odds by running a Superchips 1705 for about 200,000 miles before getting my Hydra.
Knowing what I know know about PHP and their tunes, I wish I would have switched much sooner but such is life.
I'd just keep up with maintenance and fresh fluid and start a savings account for a new one.
Old Jun 11, 2016 | 03:37 PM
  #34
RBerry9511's Avatar
RBerry9511
My 2000 limited 4x4 7.3l just turned over 250k last week. She is still going strong. I need to fix a leaking pedestal and reseal my fuel bowl. Small issues really I just want to take care of them.
Old Jun 13, 2016 | 02:19 AM
  #35
2002exPSD's Avatar
2002exPSD
02 ex 7.3 just broke 225,000 miles today
3 rear axles
3 transmissions
1 fuel bowl rebuild
Minor repairs
02 f250 7.3 351,000 miles
2 rear axles
Original transmission
1 fuel bowl rebuild
Minor repairs
Old Jun 13, 2016 | 06:07 AM
  #36
Jointasset's Avatar
Jointasset
3 rear axles
3 transmissions
1 fuel bowl rebuild
Minor repairs
2 rear axles
1 fuel bowl rebuild
Minor repairs
3 transmissions and 3 rear axles ar 225k- are you the one that lost to Grave digger in the finals?
Old Jun 13, 2016 | 08:02 AM
  #37
michaelg10's Avatar
michaelg10
Just passed 220k. Rebuilt transmission at 200k.
Old Jun 13, 2016 | 11:16 AM
  #38
2002exPSD's Avatar
2002exPSD
LOL. I wish. 1st axle went out prematurely at 90,000 miles don't know the cause, 2nd one was used out of a f-250 with 180,000 miles went out around 170,000 miles, and the 3rd one is out of an f-250 with 60,000 miles still going strong.
1st transmission blew the front pump seal and overheated at 160,000 miles pulling my work trailer up a fire access road. Had it rebuilt by a local shop. Started slipping 20,000 miles later and warranty was only 1 year or 12,000 miles. At 190,000 miles the front u-joint of the rear driveshaft broke loose at freeway speeds and destroyed the rear driveshaft and cracked the transmission bell housing 3/4 of the way around. I fixed the u-joint and drove the truck 250 miles home pulling my work trailer very slow. Insurance company replaced transmission and rear driveshaft with a new one from ford.
Old Jun 14, 2016 | 09:42 AM
  #39
Griff350's Avatar
Griff350
Just hit 300k on my 03 7.3, I think the tranny is in need of some help, but thats it.
Old Jun 14, 2016 | 11:19 AM
  #40
CheckYosef's Avatar
CheckYosef
I'm at 221,000 on my 2000 x, still going strong with the stock tranny.
Old Jun 25, 2017 | 06:50 PM
  #41
Stilllookin
Updating; rolled 272,000 today. Still stock aside from a Hypertech tuner left in level 1, a 4 inch exhaust and a 18 inch wide, ten row Trucool trans cooler. Changed the trans fluid at 266k and nothing in the pan other than usual clutch dust so i guess its gonna go past 300k with stock tranny. I do have a front axle seal leaking though.......
Old Jun 25, 2017 | 07:19 PM
  #42
Stebs's Avatar
Stebs
412k here, 02 limited... I purchased from the original owner just a month ago, however, I personally drove it home from the dealership when he bought it new back in 02 and have driven it ever since. Oil cooler at 100k, and I just replaced the hpop lines and pass fuel line, otherwise, everything else is factory except for starter and alternator...
Old Jun 25, 2017 | 09:43 PM
  #43
xrsfsho's Avatar
xrsfsho
2002 limited just shy of 316k. purchased last December. i am third owner. 1st is a diesel mechanic, 2nd is a pro suffer and drive highways up and down the coast.
done a few things to it since I bought it.
I installed:
203* thermostat
WW2
AFE stage 2 intake
it had:
edge attitude cs
diamond eye 4in exhaust
~4in lift
35s with 17 rims
have a friend with a ​​​​​​99 f350 dually qith over 500k and just lightly modded and still runs strong. it's mostly a tow rig though
Old Jun 25, 2017 | 11:47 PM
  #44
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
441K on my 2001 Excursion original engine, bought new with only 50 miles.
Old Jun 26, 2017 | 07:16 PM
  #45
pgguru's Avatar
pgguru
Just about to hit 350K miles Have a PHP Hydra keep the 65 Daily and 80 Tow Tunes on it
