Hello all from Canada.
I have a 2002 f150 with power mirrors no heat no turn however it is wired to the connecter for the turns. I am also adding heated mirror glass and would like to use the stock connector but it dose not have the male or female pins inside the connectors, the slots are empty. Can these pins be purchased. I could find a doner truck to scavinge, or just install seperate connectors.
A GOOD electronics store (not an electric store) may have the pins you need. Maybe even Radio Shack. Take the plug in with you.... I realize you may have to cut the wires to do that, but you sure don't wanna guess at the size. Leave yourself enough wire to splice it back together. Solder the wires and use shrink wrap, THEN electric tape.
