ranger light problems?
Old Nov 13, 2006 | 11:21 AM
bowtieman's Avatar
bowtieman
Question ranger light problems?
1994 ranger no brake lights unless I have the lights on
lights have to be between headlight and marker light on the switch,
for the rear lights to work at all
replaced the turn sig switch
the headlight switch
with headlight switch all the way out I only have headlights, no markers, and no brake lights?
any help??
bowtieman
Old Nov 13, 2006 | 03:30 PM
Franklin2's Avatar
Franklin2
For the marker light problem, you either have a blown fuse or a burnt connector or wire at the headlight plug.
There are seperate power supplies going into the headlight switch for the headlights and the marker lights. Your marker light power is missing. You are getting power to the markers by fudging the headlight switch contacts in a inbetween position, so the markers are getting power from the headlight power supply. That's why they work with the headlight switch in a odd position.
Your brake lights. Does your high mount third brake light work on the cab?
Old Jul 10, 2012 | 09:06 AM
JOB1963's Avatar
JOB1963
94 Ranger brake lights
Just purchased a 94 Ranger 4.0 2wd w/56,000 original miles. Runs beautifully but,,,same issue with brake lights and marker lights. Turn on the 4-ways and Brake/turn signals both flash. I still have no brake lights when operating normally? Any help will be greatly appreciated.
Old Jul 10, 2012 | 11:32 AM
Franklin2's Avatar
Franklin2
Does your third brake light work mounted on back of the cab?
Old Jul 10, 2012 | 12:02 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
No brake lights point to the BOO (Brake On Off) switch located at the top of brake pedal. The Emerg flashers and brake lights are on separate circuits. It does show that the bulbs are good. Do you have regular tail lights?
Old Jul 10, 2012 | 12:34 PM
JOB1963's Avatar
JOB1963
It wound up being a faulty headlight switch on the dashboard($20 at O'Reillys) and a blown fuse. All good now Thanks
