help need some options
Old Jul 9, 2012 | 05:18 PM
ampslw's Avatar
ampslw
i have a f350 2004 6L leaking old bad from rear seal
some said you can repair with a speedy sleeve with out pulling out motor
Old Jul 9, 2012 | 06:51 PM
Maxium4x4's Avatar
Maxium4x4
Is your ICP under the turbo or on passenger side valve cover? Why would the speedy sleave, if your rear main crank seal is leaking, be any better than installing a new one? You would move the trans back instead of pulling the engine.
Old Jul 9, 2012 | 07:09 PM
ampslw's Avatar
ampslw
Can the rear main be changed with out pulling oil pan off after moving the tran out of way
Old Jul 9, 2012 | 07:30 PM
Maxium4x4's Avatar
Maxium4x4
The block is 2 piece so you would not disturb the oil pan. Rear view
Old Jul 9, 2012 | 07:35 PM
cheezit's Avatar
cheezit
vote goes to best question ever right here.
Old Jul 9, 2012 | 09:33 PM
BLADE35's Avatar
BLADE35
Iv only done a couple rear mains none was on a 6.0L but have been able to get the new Seal on with trans Off
I have heard about a Special tool for the 6.0L to install a Rear Main seal
matt71
Jun 23, 2008 03:31 PM
Bullride_101
Sep 22, 2007 10:39 PM
1988 f 350 ford
May 17, 2007 02:10 PM
mmbintn
Mar 25, 2006 03:52 PM
42thefloor
Sep 14, 2005 11:11 PM
