Rear Main
Old Mar 25, 2006 | 09:53 AM
mmbintn's Avatar
mmbintn
Rear Main
Ok I have a oil leak from the rear of the oil pan, its not bad just annoying. Is there a way to tell if its the rear main without dropping the oil pan? Also in the 95 351 is it a 1 or 2 peice seal? And if its a one peice do I have to drop the crank to replace it. Thanks, Micah.
Old Mar 25, 2006 | 10:56 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Mar 25, 2006 | 03:52 PM
baddad457's Avatar
baddad457
Not sure when the 1 pc was installed in 351's but if it is a 1 pc seal, all you need to do to replace it, is unbolt the transmission and slide it back far enough to allow acces to the back of the crank. Pull the seal and drive the new one in place. No need to drop the oilpan or crank with a 1 pc seal.
