1972 crew cummins
Old Jan 7, 2013 | 08:03 PM
smitty3215's Avatar
smitty3215
It's been awhile since I posted. I have gotten a lot done the airdog fuel system is mounted. I got the transmission cooler and lines done and most of the p/s hydroboost is done. I also got my 63/68 turbo mounted and plumbed.
Old Jan 11, 2013 | 03:26 AM
co425's Avatar
co425
What power steering pump are you using to elliminate the vacuum pump? I have no need for one as I will be running hydro boost as well.
Old Jan 11, 2013 | 08:25 AM
smitty3215's Avatar
smitty3215
It's out of a 4bt from a bread truck. Then get a flow valve for a ford rack and pinion otherwise you will blow your seals out of you gear. I found the pump over at 4btswaps.
Old Jan 11, 2013 | 09:17 PM
co425's Avatar
co425
Thats what I was thinking it was. I am going to be running a saginaw steering box too. I believe that should match and the flow valve should be fine. Thanks for the info.
Old May 6, 2013 | 09:39 AM
smitty3215's Avatar
smitty3215
Well it's been awhile winter is now gone so I got this motor temporally plumed for a test fire. It took awhile because I had the pump retaraded. Once I got that right it fired right up. All I can say is omg this thing is going to be scary to drive the throttle is scary touchy. Guess I got my goal plenty of hp lol.
Old May 6, 2013 | 09:17 PM
grinnergetter's Avatar
grinnergetter
Nice job so far. Working on my own 72 2wd/cummins conversion.
Old May 6, 2013 | 11:01 PM
crazed87bronco's Avatar
crazed87bronco
Got any updated pics? Glad to see you fired it up for the first time. That 63 turbo should spool great not to big and laggy. Whats the exhaust size on the turbo? I been thinking of either a 63 or 64 for both my sled puller and my 71 crew conversion. Where did you get the flow valve for the power steering ill need one I'm using a 79 f259 4x4 box and the 12v ps pump.
Old May 7, 2013 | 08:38 AM
smitty3215's Avatar
smitty3215
I think it's a .81ar I have to look the valve I got from summit it is for a Chevy pump to mustang rack and pinion. I'll get some pics it look like crap because I just plumbed everything wherever it's comming apart this summer once I get a few other things done.
Old Jul 3, 2013 | 11:53 AM
78f3504x4's Avatar
78f3504x4
subscribed!
Rebel Off Road
Aug 11, 2022 08:02 PM
Raleigh1
1978 - 1996 Big Bronco
682
Mar 18, 2016 01:29 PM
jonesa49f1
15
Jan 29, 2015 08:13 AM
gilby959798
Jun 22, 2012 09:15 PM
