Oil pan source
Old Jun 25, 2003 | 10:52 AM
blu's Avatar
blu
Oil pan source
That'll just get clearance to pull the pump and replace the gasket.
JB weld might hold you over on the hole - for quite some time.
I thought when I did my gasket - if I had cut the exhaust I could have slid the pan out.
I'm not sure if I would have next got caught up on the transmission which was lifted to the max as it was.
Old Jun 25, 2003 | 09:40 PM
paulfix's Avatar
paulfix
Oil pan source
I replaced oil pump on my old truck years ago using the cut pipe method and extreme engine jacking on a 2wd F250. Took me 10 mins to wriggle the pan out and another 10 to get it back in again. I dont think I could have done it one a 4wd truck.
Good Luck
