Oil pan source
Old May 9, 2003 | 06:11 AM
tommowry's Avatar
tommowry
Oil pan source
I am going to have to change the oil pan in 94 E 150 with 5.0 shortly. I am wondering if there is an online parts source out there with good prices on the pan.
Old May 9, 2003 | 08:07 AM
luke_trash's Avatar
luke_trash
Oil pan source
I'm also interested if there are any aftermarket pans that fit, and are made of thicker/better materials.
Old May 9, 2003 | 08:52 AM
AlM's Avatar
AlM
Oil pan source
yo,
Didn't see any listed here in MotorHaven so try JEG's:
http://www.jegs.com
Tjey have plated and unplated versions; egt a price incl S+H and then compare locally at NAPA.
Out 96's pan started to rust at 62k miles. Just had it blasted, primed and painted to avois the hassle.
Old May 9, 2003 | 09:37 AM
millertime300's Avatar
millertime300
Oil pan source
Junkyard, or Summit 1-800-230-3030
They are online too Summitracing.com???
Old May 10, 2003 | 05:49 AM
54 Oldsman's Avatar
54 Oldsman
Oil pan source
Just bought one straight from the ford garage for $150. Is it any better than the original?? One can only hope!!
Old May 10, 2003 | 01:33 PM
54 Oldsman's Avatar
54 Oldsman
Oil pan source
I got the oil pan gasket set at the same time,$33.00 . Same place, the parts shop at the ford dealership.
Old May 11, 2003 | 09:54 AM
camarokid81's Avatar
camarokid81
Oil pan source
if you get one from a junkyard they are resurfaced and i dont like that. i got mine from autozone it was 60 bucks and the one peice gasket was 20 i have changed 3 of them pans now 1 on a truck and 2 on e150 vans.
www.autozone.com
Old May 11, 2003 | 11:03 AM
tommowry's Avatar
tommowry
Oil pan source
www.autozone.com
Any hints for E 150. And I did see the one listed at Advance but price was 75. Is it cheaper for F series and are they the same.
Thanks
Old Jun 10, 2003 | 12:12 AM
camarokid81
Oil pan source
i would think a chrome plated pan would last longer then just a plain painted steel pan because before it gets chromed it has a layer of copper put on the steel first then it is chromed chrome will clean with the pressure washer easier then the painted pan or try using por 15 on it
Old Jun 10, 2003 | 05:46 AM
dvldog458's Avatar
dvldog458
Oil pan source
Does anyone know of a company that makes a chrome oil pan for our (4x4) 5.0's?
Old Jun 18, 2003 | 09:54 PM
RA101524's Avatar
RA101524
Oil pan source
I just ordered one from NAPA for $65. They said it should be here in a couple of days. I called about 6 local junk yards -- er, parts salvage companies, and no one had any in stock.
Old Jun 19, 2003 | 12:24 PM
dvldog458's Avatar
dvldog458
Oil pan source
Sounds good!
Keep us posted. $65 is a great desl.
Jerry D
Old Jun 19, 2003 | 04:13 PM
tommowry's Avatar
tommowry
Oil pan source
Thanks for the heads up on NAPA. I know that we are not supposed to endorse but they are my overall favorite. I did not see it listed on their website so I thought that they did not have one. I have not had to order yet because my JB Weld patch is still holding strong. I'll let you know.
Old Jun 24, 2003 | 08:07 PM
luke_trash's Avatar
luke_trash
Oil pan source
Heh.. I was under the truck tonight eyeballing my suspension (buying new shocks here this week)
I am greeted with a big ol bubble on the side of my pan that is seeping oil.
I could probably put my pointer finger right through the thing.
So are you guys serious about being able to get proper clearance simply by 2x4ing the engine after opening up the mounts? Or will that only buy me enough space for the pan gasket?
This bites But I guess misery loves company, since it's such a common problem....
I do have access to an engine hoist..
do I need to unbolt the transmission for this one???
Old Jun 25, 2003 | 10:16 AM
yellowjeep76's Avatar
yellowjeep76
Oil pan source
A good source for V8 parts is Performance Automotive Warehouse www.pawinc.com They have all kinds of rebuild stuff. There prices are the cheapest i've found. The only downer is that you have to order their catalog. I think its about $6.
