Alternator replacement
Old Jul 8, 2012 | 05:36 PM
Joe's 48's Avatar
Joe's 48
An embarrassing moment. Im trying to remove the alternator connector on a 93' f350. I've replaced many alternators however this one seems to have a unusual terminal connector(to me). Its not the connector to the voltage regulator but to the alternator. It seems that it must have some sort of a release around the plug but I can not figure it out. If anyone can help I would appreciate it. Thanks.
Old Jul 8, 2012 | 08:49 PM
powerstroke72's Avatar
powerstroke72
Moved to the correct forum.
Old Jul 8, 2012 | 10:42 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
This is odd, there's nothing unusual about the plug.
I'm assuming you have a 2G alternator. (integral regulator and an external fan on the front behind the pulley)
The 2G alternator was known to have problems with the charge plug shorting internally, melting and in some cases even catching on fire.
If you are unable to disengage the plug with the two orange/black wires just cut it off from the harness.
This plug has caused many problems and there is a directive (TSB #96214) from Ford to replace the plug any time the charging system is serviced.
The replacement pigtail plug is available from many manufacturers and is under $10 at almost any auto parts store.
Old Jul 8, 2012 | 11:29 PM
White 97 xlt's Avatar
White 97 xlt
Is this the plug you can't get unplugged?? If so you might want to search for information on a 3G swap to eliminate that problematic and fire prone plug...
Old Jul 9, 2012 | 10:12 AM
Joe's 48's Avatar
Joe's 48
Yes this appears to be the plug. the pic gives me an idea of where the clips are to be released. Thanks for the info I appreciate your help.
Old Jul 9, 2012 | 10:14 AM
Joe's 48's Avatar
Joe's 48
Thanks Jim I appreciate your help and info. I'm going out to locate a new plug and alternator. Thanks again
Old Jul 9, 2012 | 10:19 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Just FYI,
Any of these part numbers is the same as the one pictured above,
You can see the pigtails are already stripped...
Borg-Warner PT-780
Standard Motor Products S-542
Power Plug 4628011
KEM Parts 350-220
Pico 5711
Dorman 85123
Motormite 08622
NAPA VRA400
Old Jul 9, 2012 | 10:57 AM
Joe's 48's Avatar
Joe's 48
I'm heading over to NAPA to pick up the ALT. and plug.. Thanks
Brad Borchers
Nov 26, 2015 09:50 AM
ConvertedFord
Dec 1, 2012 10:16 PM
bashby
Oct 24, 2010 07:39 AM
97-psd
Aug 21, 2010 11:52 AM
muddiejeep
Sep 26, 2008 08:36 PM
