Transmission problem
Old Jul 8, 2012 | 01:24 PM
Valde's Avatar
Valde
I bought a 1980 F100 that has been in storage for 15 years. It is in good shape for its age, but there is a transmission problem that needs to be solved. It is 302 CID with C5 trans (I think, has 11 bolts in pan, 3 gears). The first gear engages with no problem and pulls strongly, but the change for second happens only with very high revs(over 3500rpm) and is not a smooth one. First thing I thougt was a oil change which revealed that there is something broken/loose in the trans. See the picture for the part that fell off from the transmission. I can't figure out what it is?
link to picture
IMG_7647 | Flickr - Photo Sharing!
Old Jul 8, 2012 | 01:27 PM
ctubutis's Avatar
ctubutis
That part was on the outside of the transmission, correct?
BTW welcome to FTE.
Old Jul 9, 2012 | 01:07 AM
Valde's Avatar
Valde
The guy who changed the transmission oils said that this came inside the transmission. He said it was most likely on the oil pan and dropped from there to ground.
Old Jul 9, 2012 | 11:32 AM
Franklin2's Avatar
Franklin2
I don't recognize that piece myself.
Old Jul 9, 2012 | 12:03 PM
ctubutis's Avatar
ctubutis
Kinda looks like it could be a 7D029 strut? The parts book sez such a strut is used in two places on the C5:
- Intermediate Brake Band
- Reverse Band
But, this is a stretch, based only on drawings from the parts book.
I shall ask Mark to take a look, he may know.
Old Jul 9, 2012 | 12:52 PM
fellro86's Avatar
fellro86
Sure does look like the connector strut to hold the band... It would almost seem it is passing over 2nd and going to 3rd... Wonder if someone tried putting different springs in the actuator. The unfortunate part is that you will likely have to tear the trans down a bit to get it put back in. It is in the front part of the trans, but not accessible without removing the pump.
Old Jul 9, 2012 | 01:34 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The strut is my guess, but I emphasize that's a guess. I have never been inside a C5.
L-ight
20
May 21, 2018 03:49 PM
cmb2481
Sep 9, 2015 09:20 PM
texanrick
Jun 9, 2015 07:49 PM
huttone
Mar 13, 2013 10:28 PM
gordonh8r
Jun 25, 2008 06:19 PM
