Sponsored by: Real Truck
'99 engine swap question
Old Aug 10, 2009 | 09:34 PM
khxor's Avatar
khxor
I am going to be replacing the 5.4 in my 99 f-250 in the near future, the service manual says to remove the transmission first ( 5-speed) Does anybody know if the swap can be done without removing the gearbox?
Old Aug 10, 2009 | 11:00 PM
ameinig's Avatar
ameinig
Coming out is usually okay. Seems like there should be plenty of room in front to get the input shaft out of the clutch disc. If it is a hassle going back in you could pull the tranny then.
Old Aug 11, 2009 | 02:17 PM
mwsF250's Avatar
mwsF250
I did not need to drop the automatic tranny in my '99 while swapping the V10 in and out. Bell housing bolts are relatively easy access if you have the intake manifold off.
Tip: Remove the fan and radiator and some of the more protruding belt driven accessories FIRST. Then you have a nice big gap between the engine and front of truck so you can stand in there to spin wrenches. Saves the back.
