Windsor 351 Timing
Old Jul 7, 2012 | 03:16 PM
Slednx's Avatar
Slednx
Windsor 351 Timing
The timing on my truck became off after i rebuilt the carb. I am lost because i have never done this before and i dont have a book to look at. I need any kind of help i can get.
Old Jul 7, 2012 | 05:10 PM
ctubutis's Avatar
ctubutis
How do you know the ignition timing is off? Did you maybe (re)move the distributor to remove the carb?
Old Jul 7, 2012 | 08:12 PM
Franklin2's Avatar
Franklin2
Do you have a timing light?
Old Jul 7, 2012 | 08:15 PM
1983F1503004x4's Avatar
1983F1503004x4
If you need to know the timing setting for your truck, it'll say on the Vehicle Emissions Control Information label on the radiator support of your truck, under the hood, over near the battery. It should say on the sticker there, as well as on the factory sticker that hopefully is still on your valve cover.
If you don't have a timing light, time it with a vacuum gauge.
Old Jul 7, 2012 | 08:29 PM
big vann's Avatar
big vann
What is the engine doing to make you think the timing is off?The engine timing doesn't change with a carb rebuild.Sputtering,hesitation or stumbling is likely due to carb tuning.Timing issues could be loss of power in lower rpm range,misfiring or hard starting among others.A description of the problem as well as a description of engine mods,mileage etc... would help us help you.
Old Jul 7, 2012 | 11:33 PM
Slednx's Avatar
Slednx
Okay, Big Vann is the only one who has helped. Sorry for everyone else. It is doing everything you just described. My dad knows his engines(use to build muscle cars) but is stumped and has been busy. He says when the engine is running the timing mark is about 4 inches back from the timing line. He cant get the timing mark to line up so he timed it to ear and it seems to be running better. I do know the carb is tuned sorta bad and i plan on fixing that. I am still learning how to do that.
BGF100
Mar 1, 2024 02:38 PM
raven3
Jan 3, 2024 08:39 PM
harrythehack
Aug 14, 2019 07:39 AM
jrome
Dec 30, 2009 07:17 PM
Benyaytugar
Apr 26, 2007 01:13 PM
