Overheating on 91 Explorer
Old Nov 8, 2003 | 09:39 AM
dmarple's Avatar
dmarple
Angry Overheating on 91 Explorer
Hi folks
I have a 91 explorer that indicates that is is running hot whenever
I turn the A/C on. It does not seem to matter whether I am running at low speed or high. Low speed + no A/C = cool
highspeed + A/C = hot.
Any ideas ?
Thanks
Dennis
Old Nov 8, 2003 | 05:16 PM
golfboy17's Avatar
golfboy17
The AC ussually generates heat when its going but the vehicals cooling system handles it so you really dont notice. Now the Over heating can be due to simply your low on coolent, check the radiator and the tank, when the engine is cool and make sure they are both full on the tank to the full cold line. It could also be the T-stat which is a cheep and ez fix, to check this let the engine warm up, and feel the upper radiator hose if its hot, then its probally not your t-stat if its cold then your t-stat is stuck open replace it, and if its not that it could be the water pump, have you been noticing any leaks? Look around the water pump and see if you see any collent around it, if its your water pump i would replace the t-stat as well, and if its not that it could be there is a block somewere in the radiator, and finally if its not that, and you have an auto trans, then that could be malfuncting causeing the engine to overheat, I wish i could give you one answer but with the cooling system there are several possibilitis...GOOD LUCK
Old Nov 10, 2003 | 07:01 PM
bikesrfun's Avatar
bikesrfun
Check the radiator. After a few years deposits build up in the radiator and collect in the cooling tubes which limits the coolant flow. This reduces the dissipation of heat which will make the engine run hotter especially when the a/c is on and the condensor is also trying to dissipate heat (in front of the radiator).
If you can remove the top hose and look inside with an inspection mirror you can see the coolant tubes and if there is a white deposit around the inside diameter of the tubes the radiator needs to be boiled out or replaced.
Old Nov 25, 2003 | 04:50 AM
jclj2003's Avatar
jclj2003
Exclamation
or u could have a thermostat stuck closed
Old Nov 25, 2003 | 06:05 AM
marragtop's Avatar
marragtop
If you're going to replace the thermostat, don't forget to get the O-ring gasket. Normally, you have to ask for that seperate.
reaydanny
1997 - 2003 F150
Jul 16, 2012 05:37 AM
firepop5
Jun 21, 2009 02:47 PM
77F250Diesel
27
May 9, 2009 03:48 PM
daddytym
1978 - 1996 Big Bronco
17
Aug 19, 2005 06:22 PM
reberhardt
Nov 8, 2002 09:08 PM
