Just died while cruising
Old Jul 7, 2012 | 11:27 AM
BDalton's Avatar
BDalton
Truck and mods in signature. I’ve had the truck nearly 6 years and never had a problem. Only on occasion do I get what feels like a slight miss at low RPM (1500 or less) but it’s never been consistent so I never worried about it.
This morning cruising at 55 and it shut off like you threw a switch. Pulled over cranked a few times and nothing. On the last crank it ‘felt’ like it wanted to start, and the tach would jump indicating some RPM. I let it set about 30 minutes and it cranked right up. Drove about another 3-4 miles and it shut off again. Left it and rode to work with a buddy.
So, since I get tach indication that would eliminate CPS as the problem, correct? I just changed oil (Rotella T6) last week. Level is full. After doing a little searching I’m leaning toward IPR. No, I don’t have a scan gauge or access to AE. Not thinking it’s the ICP since it’s a problem of just dying outta the blue, rather than a hard start.
It was dark and I had no time to do roadside trouble shooting so I didn’t pop hood yet. No smell of oil or indication that the HPOP blew.
Any other thoughts appreciated.
Old Jul 7, 2012 | 11:33 AM
F350-6's Avatar
F350-6
Dies like you threw a switch is usually electrical / sensor related. Check the tin nut on the IPR. Check the wiring to the IPR and ICP. Check the wiring below and behind the 42 pin connector. Chaffed wires in those locations can cause a stall if they short to ground.
Also consider the CPS. You did see some tach movement, but you also got it to start again. Did all the dash lights function normally when you would crank with a no start?
Old Jul 7, 2012 | 11:39 AM
BDalton's Avatar
BDalton
Well, it seemed all the 'normal' lights came on when attempting the restart. The only thing that caught my eye (and maybe it's normal) was the red battery light was the only indicator I noticed lit up after it died. But, since it cranked at normal speed and otherwise seemed normal I thought nothing of it.
No CEL or other lights remained lit after restart.
Old Jul 7, 2012 | 08:20 PM
BDalton's Avatar
BDalton
Just started it after sitting 12 hrs. Started right up, drove about 5 miles 'wheezed' once or twice, CEL came on for a sec then died, no restart. Waited about 30 minutes, restarted but romped about 6-7 times real hard then smoothed out. Drove it onto my trailer. Got home started right up drove it off the trailer.
At least it's out front and I can get to it as weather and work allow.
Any more ideas welcomed.
Old Jul 7, 2012 | 09:33 PM
novice psd's Avatar
novice psd
Are you using a chip? Sounds like what mine did, was a gold superchip bad. If so remove it and test drive it.
David
Old Jul 7, 2012 | 09:43 PM
BDalton's Avatar
BDalton
No chip on it. Just the minor mods in sig. Thx!
Old Jul 7, 2012 | 09:58 PM
BDalton's Avatar
BDalton
Just wanted to add real quick that my buddy following me said when it died it puffed out a little blue or white smoke.
Old Jul 7, 2012 | 10:09 PM
th67ss's Avatar
th67ss
Sure sounds like what mine did when the cps went south. Although mine would blow black smoke and romp and then run fine.
Old Jul 7, 2012 | 10:19 PM
BDalton's Avatar
BDalton
So there is a possibility its the CPS huh? I just always thought they just quit and that was it. At least I have a spare and it's an easy swap to try.
Old Jul 8, 2012 | 08:38 AM
cj45lc's Avatar
cj45lc
Sounds like CPS to me, the 1st time mine gave me trouble it would shut off like you turned the key off then restart & run good for a week or two then do it again.
Old Jul 15, 2012 | 03:53 PM
BDalton's Avatar
BDalton
Okay got the CPS swapped. It had a black one in it, presumed original, that was a booger to get out. The O-Ring was totally flattened and cracking. I replaced it with the handy grey spare in the glove box and just put 20 miles and about 35 minutes of driving without a hiccup. That more than doubles how far it would travel prior to the CPS swap. Anyway just wanted to close the loop on this issue. Looks like problem solved.
Old Jul 15, 2012 | 05:09 PM
12 pointer's Avatar
12 pointer
Gtlad you got it going. Quick question?? So, If you dont see any RPM on the TACH when cranking it over means the CPS aint reading???
RES86
45
May 18, 2022 12:25 AM
Punkfish
Mar 7, 2011 10:20 PM
95Z71
Dec 5, 2008 06:12 AM
wilsonk1414
Jun 14, 2006 10:19 AM
Cobratodd
Oct 10, 2005 10:30 AM
