What is this?
Old Jul 6, 2012 | 08:38 PM
gmammakn's Avatar
gmammakn
What is this?
First post from phone so bear with me. I was on day 3 of changing shocks and all was going well. Then I saw a vacuum line coming from the rear brake line. It just hangs there with a white thing on the end.
Can't figure out how to get the pic from phone. Will download later from computer.
Old Jul 6, 2012 | 08:55 PM
TrdLtly's Avatar
TrdLtly
TreadLightly
Sounds to me like a rear end breather (aka vent line). It allows the rear end vent off gases as the fluid and metals heat up. Otherwise you will have fluid running out your axle seals.
Old Jul 6, 2012 | 09:05 PM
F350-6's Avatar
F350-6
X2. It's just the vent tube for the rear diff.
Old Jul 6, 2012 | 10:56 PM
gmammakn's Avatar
gmammakn
Ok heres the pic. Editor did not work so I will try to describe it the best I can.
Rubber hose (brake line) comes into the "t" and splits into the two metal brake lines. Behine that is the rubber hose I am confused about. It does seem like a vent. The one end is attached behind the brake hose junction. The other end has the white piece on it. It is about 18 inches long. I have it curved back in the pic so you can see both ends. If it is a valve, where does it attach?
Old Jul 6, 2012 | 11:28 PM
Kdr358's Avatar
Kdr358
it looks like the rear vent tube for the rear axle
Old Jul 7, 2012 | 06:06 AM
gmammakn's Avatar
gmammakn
Sorry for being slow, but where does it go? Does it just hang over something?
Old Jul 7, 2012 | 06:46 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
The higher the better as to keep it from sucking in water just in case of submersion. You may also want to make sure that the vent is clear of obstruction such as mud and such.
bigoldtruck
Jun 18, 2018 11:10 PM
kcaddy
Apr 6, 2018 07:36 PM
cityjack
13
Apr 7, 2016 08:45 PM
Gmeanie
Aug 10, 2014 02:21 PM
beartracks
Dec 3, 2007 01:51 PM
