injector install??
Old Jul 6, 2012 | 10:18 AM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
injector install??
My truck has been sitting injectorless for 3 weeks now. Do I still need to clean out the cylinders,or would of it all leaked past by now.
Your thoughts
Old Jul 6, 2012 | 10:20 AM
GonzoCSU's Avatar
GonzoCSU
Doesn't hurt to turn the engine over. I just put the valve cover on and put 1-2 bolts finger tight to hold the valve cover on and got a big ratchet and cranked the engine over a few turns. It might have leaked past the rings by now but its better to be safe than sorry.
Old Jul 6, 2012 | 10:43 AM
diesel-fitter-bum01
Was going to do that,just wondering if I should suction it out yet. Thanks
Old Jul 6, 2012 | 07:41 PM
F350-6's Avatar
F350-6
I would have suctioned it out before letting it sit. That's a lot of fuel that has worked it's way down to the crank case.
I'd turn the crank with a breaker bar a couple of times, then bump it with the starter with the engine disabled.
Old Jul 6, 2012 | 08:13 PM
woodnthings's Avatar
woodnthings
Suck it out first, then install the injectors and remove the glow plugs. Put the valve covers on finger tight as mentioned, then crank it for 20-30 seconds.
Realslowww
Apr 18, 2015 09:43 PM
Landscape Doctor
Mar 30, 2015 06:26 AM
Montana406
16
Aug 29, 2014 08:56 AM
bublitz3
18
Nov 18, 2012 07:24 AM
old bad daddy
Oct 28, 2012 03:27 PM
