Snow Performance Tow Max
Old Jul 6, 2012 | 05:59 PM
mars1952's Avatar
mars1952
Hi: I recently installed a Snow Performance Tow Max Water/Methanol injection system. I have had a chance to play with it a little and so far I like it. But I have some questions:
1) Does anyone have a chart that lists the turbo pressures at which the injection rate changes for all three turbo boost settings (low, medium and high)?
2) What size nozzles are other people running in their 7.3 liter engines. My truck is stock except for a Tymar intake and a 4” turbo back exhaust and I am using two 620ml/min nozzles on the low boost setting without any signs of quenching (50/50 mix).
3) When the controller says 100% is the injection pressure the same for all the boost settings (low, medium and high)? In other words is the 100% injection rate the same pressure for all boost level settings?
4) What are the turbo pressures for the various injection points with the MPG max?
5) What size is the small nozzle in the MPG max setup?
6) How much is too much water/methanol? I am on the verge of upgrading my truck with new tuner, injectors and trans. And possibly a new intercooler and turbo.
Mars
Old Jul 6, 2012 | 08:50 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
dieselguy26
Sep 28, 2012 09:01 PM
Full Throttle
May 11, 2009 08:12 AM
h8pavemnt
Oct 9, 2005 10:34 PM
h8pavemnt
18
Aug 31, 2005 12:06 PM
