Front end knocks when truck rocked.
Old Jul 10, 2012 | 10:21 PM
robertc1216's Avatar
robertc1216
after watching your video, I am no longer sure. The only thing I can suggest is jack up one side at a time, under the lower a-arm and grab the top of the tire (when there is a little space between it and the ground) and try and jerk it back and forth, if there is a clunk or movement, you either need wheel bearing or ball joints. You will need someone looking at each to see where the movement is coming from.
Now do the same kind of motion but in the direction the tires move when turning. everything should move together.
Also if you have jack stands I would strongly suggest using those. and it doesn't take a lot of force to do either of those things.
Alright, I found this on youtube.com, it basically shows you what your ball joints should not do. also this is NOT me and I dont like that guy...
http://www.youtube.com/watch?v=MvOARgIVfQY
Old Jul 14, 2012 | 08:42 PM
02transam's Avatar
02transam
Well, the sway bar links didn't solve the problem. I will check the ball joints tomorrow and keep you guys updated. This is aggravating...........
Old Jul 15, 2012 | 07:02 PM
02transam's Avatar
02transam
Went back underneath the truck today..... I checked the ball joints and they are fine. I did however notice a decent amount of movement in one of my new swaybar links. I am going to try and replace it tomorrow w/another link to see if that will fix my issue.
Old Jul 21, 2012 | 01:14 PM
FORD COASTIE's Avatar
FORD COASTIE
Veteran: Coast Guard
Did you ever figure out what is causing the noise?
Old Jul 21, 2012 | 06:29 PM
02transam's Avatar
02transam
I believe so, The truck is much quieter now since I replaced the sway bar links. It still makes a little noise over large bumps but nothing like it was. I am wondering now if maybe some of the noise is coming from the calipers moving around when I hit a bump.
Old Jul 28, 2014 | 11:02 PM
2004F150SuperCrew's Avatar
2004F150SuperCrew
Defiantly sway bar links. Only way to check them is to look at the rubber on the links, and if they are dry rotted or easily squeezable, then they're bad. Just replaced mine.
Old Jul 30, 2014 | 05:20 PM
1saxman's Avatar
1saxman
'Don't come a-knockin' when my truck's a-rockin'. New song of mine. (Apologies to Stevie Ray).
whateg01
Modular V8 (4.6L, 5.4L)
Nov 5, 2015 07:24 PM
is300wrx
2004 - 2008 F150
21
Nov 13, 2014 10:33 PM
r-kid
Jun 10, 2008 07:44 PM
Turnip311
2004 - 2008 F150
Sep 20, 2006 11:13 AM
Mike in Illinois
Dec 30, 2004 11:18 PM
