Alternator Problem or Regulator Problem or ??????
Old May 8, 2003 | 08:36 PM
doczog's Avatar
doczog
My 1990 F150 is really goofy...when I start it up after setting over night, the volgate guage set way on the low side. I can tell the system is not charging, as the flasher is slow, and the wipers drag badly. Then, after a few miles (sometimes more) the needle jumps to the middle of the guage and everything is fine.
If I shut it off for an hour or two, it works normally on the next startup....it only acts goofy when it has set a long while.
I suspect a screwed up voltage regulator, but I don't know if this is internal to the alternator or external....
It is a 300 I-6 with Auto and AC....and ideas???? Thanks
Old May 8, 2003 | 09:11 PM
steve83's Avatar
steve83
'90 used an internal regulator, but a poor rectifier. Most parts stores will test it free in the parking lot.
brian1985f150
19
Feb 7, 2017 05:52 PM
scottscheffer
Dec 22, 2016 08:08 PM
mikenamys
Sep 23, 2015 08:12 AM
kamloops
1997 - 2003 F150
Apr 26, 2008 11:35 AM
