main bearings
Do worn main bearings make a knocking sound? I replaced the rod bearings with the engine still in the truck. Now I still have a severe knock esp. when the oil gets hot. I also have a HV pump in there and HOT, i get ZERO pressure. I am using this truck to pull loads of firewoord. The engine is a 74 360. How long can I run it like this? I was thinking about running straight 50 wt oil with 2 cans of thickener to quiet the rattling down some....
ideas??
regards
Ben
Typically, a main bearing out will be felt in your foot during acceleration. Does it knock all the time, just hot, just under load, or what?
at cold startup, i get like 35. Then when it gets hot, she drops to zero (guage reading). on the road @60, if cruising, it looks like 20lbs but as soon as i FLOOR it, the guage falls and then slowly creeps back up. If i let it idle, then it go back to zero and stays there. Its a regular LOUD rhythmic knock all the time. At Light tip in throttle, it sounds like really loud metal thrashing (not pinging). At idle at a red light, its like 'DUMP DUMP DUMP DUMP DUMP' (say it out loud and this is what it sounds like!
Hope this helps! Remember, I put in NEW rod bearings like 600 miles ago!
regards
Ben
Edit: That's about what my old '86 bronco 2 sounded like when the bottom end went out on it.
Thanks for the lil personal insight on yr 66. However, I didnt appreciate the sarcasm that followed. Thought I'd let ya know.
If I had to guess I would say it is a rod.
If you ever get board you can start the motor with one spark plug out at a time, and find the problem rod.
Sorry that bothered you. It wasn't so much sarcasm as it was a sad-but-true story.
That old truck had lots of problems (mostly severe rust) and the bad motor pushed it over the edge. I didn't know much about engines back then. I knew even less about pulling a motor. When I was pulling the hood off it slipped, cracking the windshield. I used an old swing-set with the come-along to lift the old engine out that wasn't stable and also swung into windshield, finishing it off. The costs were adding up too quickly, so we gave what was left of it to our scoutmaster.
I learned how to drive in that truck. I learned how to shift a manual transmission with it. I miss that old truck. I'm vowing to do better with my '72 and hope to have it running again in a couple of months. I'm picking up my freshly ground, balanced, and polished crank tomorrow.
its ok. its hard to tell here between sarcasm and a story. Its cool. I can relate to yr attachments to an old vehicle. I am very attached to my junk as well. I need to run this old bear for a lil while longer til i can fix up my 69 F250 4x4. I have to replace a busted ring and pinion and do the brakes but I am having trouble with getting that carrier out of the front housing. Besides, I need to locate the proper u-joints for the front axleshafts. I posted a question in the axle forum here.
I hope this one truck holds out a lil while longer. I mean its really rapping away. Its almost like a bad death rattle. I forgot to mention that I just noticed that it is starting to smoke. It never did that before. I wonder if this has anything to do with the knock. As far as pulling the plug wires to isolate the noise, I did that and it still knocked each time. Like i said, Im hoping for 2 more weeks out of this! Id hate to see a rod go through the block. Ya think 50 weight oil and additive will buy me more time??
regards
Ben
It could be cracked or sucking air... and have enough pressure with thick oil, and as it heats up and thins out... NOT.
You did torque the rod cap bolts with a torque wrench, right?
The other guys were right on, but down to copper will run a loooong time if you are gentle, so something else happened, I think. Drop the pan, and throw a set of mains in there. Check the rod inserts one more time. Check the pump when you drop it. It CAN last if you don't go too many miles with the shot bearing.
Heck, I had a 390 with the rearmost main insert turned inside the cap... NO NOISE??!?!??!!!?! Just a bad rear main seal leak... New inserts, new seal, and off she went....
tom
If it's only a matter of it lasting a couple of more weeks, I think I'd borrow a friend's car until your other wheels are back on the road. Then you can take your time with a nice rebuild.
I'm in the process of rebuilding mine. Got the crank back today and will bore the cylinders next week. Heads will be done a couple of weeks after that.
Good luck!
--Matt
