fast help needed
Old Jul 4, 2012 | 08:53 AM
enriched&beyound's Avatar
enriched&beyound
fast help needed
OK my son & one of his buddies got in on a engine swap of a 92' f1504x4.
now converting a 86' to a 92' 351/5.8. They have been working after hours, with it being SOooo hot, progress has been slow. now the owner wants his truck ASAP
basically they pulled a tired 5.8 out and swapped in a better (possibly), engine from a 86'. They swapped the intake from the 92' engine but used the heads from the 86' to put it in the 92' f150.
the question is... what is this exhaust port out the front of the heads (both banks) & what size are those threads???...(guessing 5/8-11 or are they metric?), so they can plug them.
the 92' heads have some sort of insert threaded in them....kinda doubt that they can be removed, gonna suspect they were lock-tighted in.?? IDK
Have they short stepped their way to a bunch of headaches by not keeping the 92' heads?
appreciate the help
Old Jul 4, 2012 | 03:05 PM
enriched&beyound
Oh yeah forgot to mention, exhaust comes shooting out.
its the larger hole above the frost plug
Old Jul 4, 2012 | 08:14 PM
smalltrucker's Avatar
smalltrucker
Your guess of 5/8-11 is correct!
Dave
Old Jul 5, 2012 | 06:56 AM
enriched&beyound
Dave
Thanks! managed to find to find a couple bolts.
apparently these holes were for air injection...& not needed for EFI engine
Old Jul 5, 2012 | 03:29 PM
Conanski's Avatar
Conanski
Your boys put the heads on backwords, and not only that they removed the relatively high compression EFI heads and installed low compression smog heads. Those large air injection holes are supposed to go to the back where there is a tube connecting them with a series of valves and the air pump, and yes that system is on these EFI trucks.
Old Jul 5, 2012 | 06:58 PM
enriched&beyound
thanks...truck is delivered but I'll pass it along all the same.
I did notice several engine builders (on line) have mounted them wrong then too.
in regards to the original heads...they were run way too long with a bad head gasket....melted a rim of a couple pistons & were warped pretty badly. & the original heads had the front ports plugged
Old Jul 5, 2012 | 07:37 PM
smalltrucker
Usually the front ones have a thread reducer from the 5/8" to 7/16-14 to mount the acc. brackets. I got a set of AFR heads that were both the same, both had the inserts for use on the right side of motor,
Dave
Old Jul 5, 2012 | 09:12 PM
enriched&beyound
Dave
yep, the old engine and heads had these "inserts". they tried to remove them but tore them up too much in the process ....presume some loc-tite was used
guinness2199
Mar 16, 2005 02:42 PM
John Casey
Feb 24, 2005 05:30 PM
h-m
Sep 15, 2004 11:14 AM
c_rossman
Nov 13, 2003 08:55 PM
