76 F100 A/C delete
Old Jul 3, 2012 | 06:59 PM
bigreed91's Avatar
bigreed91
76 F100 A/C delete
Hey guys quick question. i have a 76 f100 with a 360 with factory a/c. The compressor has long since been removed and id like to get rid of the big evaporator box on the passenger side. I hate how crowded it makes my engine bay and how hard it makes it to change that back spark plug. My brother has a 76 (or so he thinks) that came factory without a/c. Is there a panel on the passenger side i could just swap no go to the factory non a/c look or would i have to do a custom sheet metal job of some sorts? Any ideas? Thanks.
Old Jul 3, 2012 | 07:47 PM
hasteranger's Avatar
hasteranger
you can just cut the firewall out where the ac box is and weld it in, probably the easiest way. Otherwise just weld a piece of steel in there.
Old Jul 3, 2012 | 08:52 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yeah, there isn't a "plate" that bolts in place. A/C and non-A/C trucks used different firewalls.
Like hasteranger said, you can weld in the non-A/C section or you could fabricate a block off plate that will cover the (big) hole in the firewall.
Here's a picture of an A/C firewall...pretty big hole.
Old Jul 3, 2012 | 09:15 PM
garthneddy's Avatar
garthneddy
Why not just get a new compressor and run with a/c? Local junkyards in my area sell them for as little as 25 bucks with a warranty and you could be one of the few guys with a dentside that has working a/c
Old Jul 3, 2012 | 09:26 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Factory installed integral A/C is combined with the heater. The A/C controls are located in the same panel as the heater controls.
If you remove the A/C, you won't have a heater. Then what will you do?
Old Jul 3, 2012 | 09:47 PM
hasteranger
welding in the non AC panel allows you to keep the non AC fan setup.
Old Jul 3, 2012 | 10:05 PM
Aaron-71's Avatar
Aaron-71
If you don't want to make it 100% permanent, you can always just rivet a panel where the A/C hole is and seal it up with some sort of silicone.
I plan to just rivet a panel, making very few holes and siliconing the panel to my cab so i can get A/C later when I've got enough moneys...
Sure it's temporary, and not permanent... but it's doing the job its intended to. I'm only driving it around town on weekends anyways..
Old Jul 4, 2012 | 02:34 AM
bigreed91's Avatar
bigreed91
well i really dont want a/c, its an eye sore to me and probably 75% of vehicles ive had i ve removed it, the only thing i was concerned about was the heater core, i didnt know if it was in the dash or beside the evaporator.
FLgargoyle
Sep 27, 2018 06:23 PM
Mdc9966
13
Sep 22, 2015 09:40 PM
scottness2
WTB - Parts & other
May 7, 2015 07:57 PM
greatbargins10
Jan 7, 2012 09:31 PM
jleinweber
Jun 2, 2005 10:51 PM
