HArd time starting
Old Jul 3, 2012 | 08:48 AM
JMalmy21..00/7.3's Avatar
JMalmy21..00/7.3
HArd time starting
<HR style="BACKGROUND-COLOR: #ffffff; COLOR: #ffffff" SIZE=1> <!-- / icon and title --><!-- message -->
Okay, here it goes.
With the fuse in for the horn, my truck has this interesting problem when i try to start it. Ill put the key in the ignotion and turn it to the on postion to allow the glow plugs to heat up. Now most of the time all the lights in the gauge area will come on, gauges will do their normal thing, air comes on, radion fires up. W the horn fuse in the only thing that happens is the air comes on.....NOTHING else!! If i try to turn it over it just gets stuck trying to fire up. Ill release the kay back into the ON postion and TTHHEENNNN all the lights, air, gauges, and radio come on. Now that the horn fuse is back out of the fuse box, it works perfectly...
Any thoughts??!!?!?!?!
This has put all my upgrading to a hault, sad
Old Jul 3, 2012 | 09:30 AM
fordpride's Avatar
fordpride
When the fuse is in does the horn work?
Old Jul 3, 2012 | 09:35 AM
JMalmy21..00/7.3
Yeah it does work
Old Jul 3, 2012 | 10:12 AM
njjeeper's Avatar
njjeeper
Thats odd! I would pull the wires to the worn and put the fuse back in. Same problem, then hook the horn back up and unhook the horn wires from the switch on the steering wheel. Then try again. If its still there after that I would be looking behind the fuse panel for the penny or other metal object thats back there casuing a short....
Old Jul 3, 2012 | 10:19 AM
JMalmy21..00/7.3
Okay man thanks. I appreciate it
EvanBly
Transit Connect
Sep 16, 2016 03:57 PM
Ridenred333
Apr 25, 2013 10:43 PM
Texas450
6.4L Power Stroke Diesel
Nov 5, 2012 04:03 PM
jayc3169
Mar 7, 2011 01:39 PM
