Ok, the moron previous owner has struck again with his jury rigged mods. My truck is a 99 f350 4x4 CC LB. Anyway he tried swapping in the grill and headlights from an 05. I went to use my hi beams and the lights just turned off completely. I took a quick look today when I had a few minutes and noticed that there area a few loose wires that are taped up. Does anyone know what wires from the 99 would go to what wires on the 05 headlights? I am under the impression that this is a somewhat common mod for the 99 crowd so I am hoping someone has a good write up that I haven't been able to find yet.
I wish I could do that but he cut the plugs off completely and did some crazy wiring. I have plugs to replace everything and make it right I just don't know which wires are what.
Attached is a diagram. Just figure out which wire is for high beam and which one is for low beam. Pretty simple to wire up then.
