Does anybody know if the hubs on a 2003 F150 Supercrew need to be repacked if the truck has been driven through water? I know that you used to have to repack them after driving through water but i don't know if that is needed anymore.
You cant repack the hubs on your truck. The hub/wheel bearing assembly is sealed. After going through much water you should check the oil in your diffs and transfer case though and maybe grease any fittings you have which is probably just 2 on the idler arm.
