P code P0171
Old Jul 2, 2012 | 11:18 AM
popeye47's Avatar
popeye47
P code P0171
Hi guys i am getting a pcode P0171 running lean on bank 1. Is bank 1 on the passenger side? is this code the upstream 02 sensor or should i be checking other things as well.
Thanks
Old Jul 2, 2012 | 11:32 AM
Moto Mel's Avatar
Moto Mel
The first thing to check is the 90* vacuum connections at the intake manifold, the one at the rear of the manifold is the most likely problem. They usually come apart in the inside of the elbow. Autozone has the part in the "Here's Help" section.
Old Jul 2, 2012 | 11:13 PM
popeye47's Avatar
popeye47
Found the vacuum leak right at the pcv valve. Nice easy fix.
thanks
Old Jul 3, 2012 | 09:32 AM
Moto Mel's Avatar
Moto Mel
thanks
If it was the elbow you might want to replace any others, especially the 1 at the rear of the intake manifold.
Craig Householder
1983 - 2012 Ranger & B-Series
Aug 11, 2013 10:44 PM
red85k100rs
Mar 12, 2013 02:23 PM
Hog rider08
1997 - 2003 F150
Feb 5, 2013 02:05 PM
dhag911
Feb 11, 2007 10:09 PM
99UAV
Feb 27, 2006 09:51 AM
