04 powerstroke tranny problem
Old Jul 1, 2012 | 08:39 PM
joe_r_dog's Avatar
joe_r_dog
My cousin has a 6.0 thats giving him problems now. He's had it for 6 years and I think it has a bigger turbo and injectors. It has an egr delete and the oil cooler was replaced not too long ago. It has 170k on it and his tow/haul is flashing which I know has a code stored and his gauge will drop down and come back to normal. It also says check gauge right next to it. The sensor has been changed three times. He's lost. He also saidbit will drop out of gear sometimes when driving and will randomly come back in.
Old Jul 1, 2012 | 08:42 PM
m-chan68's Avatar
m-chan68
The late-2004/early-2005 seems to be the model year range that had issues with the TFT sensor and/or internal transmission harness to make this an otherwise bulletproof transmission that is ten times better than the 4R100 it replaced.
Old Jul 1, 2012 | 08:52 PM
Rusty Axlerod's Avatar
Rusty Axlerod
What kind of tuner?
Old Jul 1, 2012 | 08:58 PM
joe_r_dog's Avatar
joe_r_dog
Don't know. I know that sct is the best but he had it tuned and I believe he said he sold whatever tuner he had on it
Old Jul 2, 2012 | 09:40 AM
joe_r_dog's Avatar
joe_r_dog
Anybody hear of this kinda thing happening? Could this just be his tranny going out??
Old Jul 2, 2012 | 09:45 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Did you see M-chan68's post about the TFT sensor? Scroll up a few posts.
Old Jul 2, 2012 | 01:47 PM
69cj's Avatar
69cj
Correct me if I'm wrong Mike but, the tft sensor wouldn't cause the tranny to drop in and out of gear would it? Sounds more like a tuner/solenoid problem to me.
Old Jul 2, 2012 | 01:52 PM
m-chan68's Avatar
m-chan68
NOPE. The most obvious symptom of a failed or failing TFT sensor is for the Trans Fluid Temp gauge not to function, along with a loss of TFT input to the PCM. As far as what other symptom to expect, I couldn't tell you, other than the only difference between COLD and HOT operations that I'm aware of, are the torque converter lockup and the transmission fluid cooler bypass. Dropping in and out of gearing sounds more like a low fluid level type of concern.
Old Jul 2, 2012 | 07:31 PM
joe_r_dog's Avatar
joe_r_dog
I saw his post and the sensor has been replaced 3 times he said. But the wiring harness thing I will have to tell him about. I don't see him often but I've heard of the sensor being a common problem before
maximuse34
Jul 29, 2013 08:26 PM
PRDATOR
Dec 15, 2011 11:35 AM
spocky1187
Dec 6, 2011 11:25 AM
B846B
Mar 31, 2011 06:39 AM
RPharr
Mar 10, 2005 07:02 AM
