Is it over yet?
Old Dec 5, 2011 | 07:12 PM
spocky1187's Avatar
spocky1187
Is it over yet?
So....... new to the diesel world and did a ton of reading before I finally bought a 06 F-350 6.0PSD with 75k I love the truck but ive had it about 2 months now and have done EGR valve and cooler and Oil cooler and most recently FICM. I know I should have done studs while doing coolers but couldnt afford the extra cash. As of know is there anything else that may cause me issues in the near future from what Ive been able to read on FTE I hit most of the comon problems, can you think of any others? Also Im looking into doing EGR Delete and buying a tuner am I safe running a tune with no headstuds? also looking at Scangauge II but i dont think it will read EGT should I add gauge for that? Sorry for all the questions still very new and trying to learn. Thanks
Old Dec 5, 2011 | 07:19 PM
2006powerstroke90's Avatar
2006powerstroke90
As always were here to help
My best advice is to buy a scan gauge II to monitior your FICM voltage, ECT VS eOT temps.
Do NOT tune it with out headstuds. I don't care what anyone says, I just wouldn't. Then again, I know a guy with an 05 6.0 190cc injectors and an SCT tune, and his HG's show no signs of failing. Its really a do at your own risk thing.
Deleting your EGR system is illegal, but MANY people do it.
Old Dec 5, 2011 | 07:23 PM
spocky1187's Avatar
spocky1187
Thanks for the feedback is EGT temp gauge important if im not running tune ?
Old Dec 5, 2011 | 07:27 PM
2006powerstroke90
Unless your towing a massive trailer, I wouldn't not concern to much about it.
Old Dec 5, 2011 | 07:47 PM
BLADE35's Avatar
BLADE35
Id get some gauges like Tyler mentioned scangauge Edge insight whatever but something to watch some things with
Fuel Pressure and EGT have no factory senders for these so you have to start from scratch on these. ScanGauge is a GREAT Start IMO
Then you might want to look into some of the cheap reliability Mods like the Blue Fuel Spring, and a Coolant Filter, Synthetic oil, ELC=extended life coolant, CCV Reroute, Harpoon mod
I wouldnt throw a tune to the truck without ARP studs either
But they do have tunes advalible for Non-Studded trucks
Old Dec 5, 2011 | 08:56 PM
spocky1187's Avatar
spocky1187
Thanks a lot for all the info would a tune for non studded truck be not a good? An if I layer on decide to buy studs and add them what kind f shop cost would I be looking at ? I wish I could of done it while coolers were getting done I might of shot myself in the foot. Thanks for all the info please keep it coming
Old Dec 5, 2011 | 09:00 PM
spocky1187's Avatar
spocky1187
also blue spring is that an OEM part that I can get from ford or where is the best place to get it?
Old Dec 5, 2011 | 09:10 PM
BLADE35's Avatar
BLADE35
Yes the Blue Spring is OEM and can get from ford dealer
On the Tunes I have read that it does add Preformance Im not shure whats all involved with it
its an SCT tunner with a custom tune You could ask the Tune writer about what all it does
Or maybe someone that has one will chime in here
Best thing to find out about the tunes would be to start a new thread Titled tunes for non studded truck or something you will get the answers you want or you could use the search box at the top of the page
Old Dec 5, 2011 | 10:25 PM
firedaniel's Avatar
firedaniel
I have a 06 like you but with 200k miles on her. I have done everything you have including SCT, Oil cooler, EGR delete, Coolant filter etc. I have a Scan guage on it to show what all is going on. I think my FICM needs alittle help but I think its all good. I did get a tune because the check engine light came on when I blocked the EGR cooler. I dont have studs in mine but am not too worried about it. Matt at gearhead did my tune and I highly recommend it! I am using the 8k tune and just keep my foot out of it. It has the power if I need it it does add a good bit of power better mpg and the trans shifts great.... I definitely like mine...
I think you have hit all of the highlights... Now its just fun mods...
Daniel
Old Dec 6, 2011 | 11:07 AM
texans's Avatar
texans
depends on the shop labor rate. You could pay anywhere from $1,800 - $2,500 in labor + parts. Where are you located at? I do them on the side for $1,000 in labor
Old Dec 6, 2011 | 11:09 AM
spocky1187's Avatar
spocky1187
Northern Illinois
Old Dec 6, 2011 | 11:25 AM
jdadamsjr's Avatar
jdadamsjr
just like with ANY used vehicle, some are good, some are not so good
same goes with what you MUST do before tuning...
in my last two 6.0 Ex's all I did was exhaust updates to lower egts' and then tuned via the IDP Extreme street.... current truck now has 140k HARD Miles and running like a scaled ape
no studs, no egr cooler, no etc....
YRMV
scrdanis
Jan 8, 2021 12:10 PM
motomax55
Jun 11, 2015 06:26 AM
ThePowerNoob
Feb 16, 2014 06:20 PM
add2255
Jun 21, 2011 05:39 PM
carcus
Jan 25, 2011 08:10 AM
