Return fuel line replacement
Old Jul 1, 2012 | 09:11 AM
Vince dEon's Avatar
Vince dEon
This has got to be simple, right? I am barely a shadetree mechanic so bear with me here.
I have a fuel leak. A buddy says it's my fuel return line and I've seen it myself.
I have removed the airbox to get at stuff and am trying to R&R the return fuel line from the rear drivers-side of the engine down behind the block to where it meets up with the metal return line.
I have totally loosened the hose clamps at each end but cannot pull off the rubber hose. I have a feeling I'll have to slice the rubber hose to remove it totally but don't want to damage anything ...
1. Are the lines and the Tee barbed to hold the hose in place?
2. Is the Tee plastic or metal?
thanks
Old Jul 1, 2012 | 11:35 AM
farmert's Avatar
farmert
1yes, there are barbs on the ends.
2 The caps on the injectors ar plastic, the tee on the rear of the engine is brass.
It would be a good idea to replace the o-rings under the plastic injector caps, and the rubber lines in between them while you are there as desterbing the caps breaks the seal, and the harden o-rings will not reseal giving you another place for air to get into the system.
Old Jul 1, 2012 | 11:46 AM
Vince dEon's Avatar
Vince dEon
Thanks - I'm just replacing this one line and not all of them, and now know what I need to do.
Many thanks!
Old Jul 1, 2012 | 02:15 PM
lemonshindig's Avatar
lemonshindig
You really should do them all. It's the most common maintenance item on the idi. You can get a top-notch kit to do this from typefour (a user here) for like $40, and it only takes a couple of hours to do. If you only repair one, then something else will leak soon enough.
Old Jul 1, 2012 | 02:36 PM
Vince dEon's Avatar
Vince dEon
Thanks - point well taken. When I have a predictable income stream again, glow plugs and these lines are on the list as well as replacing a fuel tank and an exhaust line. For now it's bare minimums.
bob_351
Jun 1, 2008 10:12 PM
68dutchguy
Jun 11, 2007 11:22 PM
73strokin
Jun 2, 2007 07:29 AM
skidplate
May 17, 2006 09:28 AM
kidoo
Mar 13, 2006 12:20 PM
