I have heard it in the morning but really not during the day. Havent really paid attention to it before. But I do know what you are talking about. I dont think I have ever had my truck to 4500 rpms, maybe once or twice taking off fast. Never pulled anything over 3500lbs. THe think is it has been heating no matter what the temp outside is. The temp the other day was low 70's.
I live on a military post and usually only drive it a couple hundred miles a month. Between 2 to 4 hundred unless I go for a long drive. My wife drive it daily to get kids from school on post about 2 miles round trip and maybe 30 miles on the weekend.
Ok so I am still having the overheating issue took it to a local mechanic and we spent about 7 hours going thru everything we can think of. I replaced the clutch fan this morning, we popped the thermo stat out and checked it, it is working fine. opened up the heater hose and started truck up there was plenty of pressure of coolant coming out to see if the water pump was pumping good. There were no other signs of pump issues to begin with. We also took if for a drive hooked up to the scan just to make sure that when the temp guage on the truck said it was hot it was we could see what temp it really was which the computer showed 265. We also opened the petcock up to see if there was crud sitting in the bottom of radiator, seemed to be clean. We also did a leak down test to see if it had a blown head gasket and it was fine. I did flush this truck twice about 8 months ago the only other idea that came up was took take out the regular green coolant that is in there and put ford's gold coolant. Anyone have any other ideas I am just getting frustrated as I don't want to buy all new parts and it still not fix it.
get a meat thermometer and get temps off the radiator hoses. You should see 20-30 temp drop across it. I failed to read this entirely, did you put a new cap on it?
I jumped in late . You say it is overheating . Flow ck your radiator , ck for plugged fins externaly . Ck for missing fin webbing . You also stated you used an IR gun . That can be a good tool to ck total system flow . Ck actual temps at all spots in the system .Does it actually " overheat " and boil over ? Or does it just show hot and go into temp protect mode ? You may have a flow issue inside the radiator , or just a faulty temp sensor . 265 should be boiling over .
We did check the radiator externally making sure it was not clogged on the outside there was a few bugs but that was it. When it was getting hot it will go in to temp protect mode however I turned the heater on before it did this and temp came back down slowly. Also when we were driving the truck we had a computer hooked up to it to compare the temp of the truck while driving it. I just bought a new radiator from napa and in the morning I am going to flush the old radiator out I have been running super flush thru it for the last two hours. I will see if any junk comes out, either way I am probably just going to put new radiator on it. If that doesnt fix it the only other thing I can think of is water pump. That being said I dont see how the water pump can be bad because like i said earlier when we cracked the heater hose open and started truck the pressure coming out was strong.
I was just thinking . Some autos use the ecm to operate the temp gauge . They use the ecm sensor only . That is why I asked if it is boiling over . At 265 it would . If IR gun only showed 180 and ecm showed 260 , you may have a bad sensor . So , is it actually overheating ?
It was not boiling but steaming, I feel like if it would have got any hotter it would have boiled it was right there. the only sensor is on the top of the engine behind the alternator. You have to either remove alternator or intake manifold.
I would still ck the actual temps . The computer can only show you what it sees . If the information it gets is bad .... Crap in , crap out ! It should be BOILING at 265 , not just steaming .
Ok, so what are your opinions on me changing out the radiator?
It may be time . You may be on borrowed time , or not . It is hard to say without seeing it . If you are able to afford it , it may be piece of mind even if not needed . If I had any doubts about it , I would change it to be safe .
