'68 Ford Noob Needs Help
Old Jun 30, 2012 | 08:52 AM
Attorney68Ford's Avatar
Attorney68Ford
Good Morning!
I have a manual on order so I can figure this issue out - but it hasn't arrived yet so I am turning here for some help if anyone can help me.
I'm new to the classic truck scene - I bought this last year for $1500 and it ran pretty well. I put in a new carburetor, kill switch and air filter (took the old oil air cleaner out, which I kept).
I have been having problems starting - usually I just needed a jump, but now I can't start it at all. I was having problems starting the truck when it was hot or had run for a while. Our temperature here has been well over 100 everyday for the last week or two.
I spoke with a friend who races (on the phone) and he thought I a sluggish starter and that I should start by replacing that (the battery is new and good).
Here is the problem - I can't find the starter under the hood to replace it. There is a captive discharge ignition - I have never worked with one of these before. I know there has to be a starter somewhere - but the new starter I bought doesn't look like anything under the hood.
I have done some repair work to newer cars - 80's and beyond, but nothing like this.
Any help, tips or thoughts anyone can offer would be much appreciated.
Sorry for such a basic question.
Feel free to email if you want me to email you some pics under the hood.
Old Jun 30, 2012 | 10:08 AM
elgemcdlf's Avatar
elgemcdlf
Originally Posted by Attorney68Ford
Good Morning!
Get on your back, slide under the truck just behind the right front tire. When you get in about a foot or so look up. That black cylinder shaped thingy with a battery cable attached to it is the starter. If you need to jack the truck up to do this make sure you properly support it with jack stands. Never trust a jack to support a vehicle.
Old Jun 30, 2012 | 12:48 PM
Flytyer24's Avatar
Flytyer24
When is the last time you did a tune up? Change your sparks, wires, dist. cap, rotor, points, condenser? Does it makes any noises when you try and start it?
Old Jun 30, 2012 | 09:10 PM
willowbilly3's Avatar
willowbilly3
Check all your grounds and make sure you have all good clean connections and a battery that has been tested good. Ford starters hate high resistance and bad batterys.
Old Jul 5, 2012 | 09:41 AM
Attorney68Ford
Thanks!
Thank you all so much for the help!
Changing the starter went pretty quickly and the truck fired right up.
elgemcdlf - It was very easy to find with those directions. The swap went quickly and easily.
Flytyer24 - There was no noise when I tried to start it up. I did a pretty complete tune up when I bought the truck last year in October. That went well, and then I rebuilt the carburetor and put the kill switch in. I hadn't had any problems until now.
willowbilly3 - Thanks for the heads up on these trucks hating high resistance. That is good to know.
I'm sure I'll be back on here soon needing some help with something else. I'll post some pics soon as well.
Old Jul 5, 2012 | 12:27 PM
arctic y block's Avatar
arctic y block
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
got2befast
Jul 27, 2019 10:00 PM
Mike1
Apr 7, 2017 01:41 PM
ottawa_dave
Jul 10, 2007 10:04 PM
misty24
May 26, 2005 11:34 PM
'70F100Owner
15
Jan 6, 2004 05:03 PM
