94 Crew Cab Rear Window Problems
Old Jun 29, 2012 | 01:17 PM
triggernut7788's Avatar
triggernut7788
94 F350, 4wd, 460, Crew Cab,
My rear windows are done. They wont easly roll up or down and wont roll up all of the way. I have new gear kits for them but I have no idea how to get to the motor. I have service manuals and everything is for the front doors not the back. If I can figure out how to get the motor out I can fix it. Im stumpped. There is no where to "drill" ethier.
On a bright note I am putting a new engine and transmission in this weekend.
Old Jun 29, 2012 | 02:40 PM
Diesel_Brad's Avatar
Diesel_Brad
You need to grind all the rivets off and pull the whole regulator out, then replace the motor. I am surprised your 94 has power rear windows
Old Jun 29, 2012 | 02:45 PM
triggernut7788
How do you re-mount the motor?
Old Jun 29, 2012 | 02:54 PM
Diesel_Brad
1/4-20 bolts & nuts
Old Jun 29, 2012 | 03:22 PM
triggernut7788
Cool Thanks
Old Jun 29, 2012 | 06:45 PM
joshh's Avatar
joshh
if the 94 is the same as my 97(dont see why it wouldnt be) look through the hole where the wire goes u can see one bolt for the motor then look down infront and back you should be able to see the other 2 i just drilled 1/2" holes to get access to them u will need skinny arms (or someone with them) but u can reach it from the hole behind the motor
Old Jun 29, 2012 | 07:58 PM
Diesel_Brad
I just gutted a crewcab door tonight to swap the glass out, It took me 10 minuets with the grinder (rivets) and a 11mm socket to COMPLETELY gut the door. Assembly would take less than 10 min
Old Jun 30, 2012 | 09:21 AM
joshh's Avatar
joshh
eithor way would work fine I had bout 25 min total time in mine including finding my stupid drill ( which was in the house)
reesecup
Sep 5, 2013 08:43 PM
Maximus77
Appearance & Dress-Up
18
Aug 31, 2011 08:26 PM
Kangus
Aug 18, 2009 07:49 AM
yagerzzz
1983 - 2012 Ranger & B-Series
Mar 4, 2009 05:51 PM
todd_mcmahon
Electrical Systems/Wiring
Nov 17, 2007 07:19 PM
