No Start. Here we go again.
Old Jun 29, 2012 | 09:05 AM
3KB's Avatar
3KB
My saga with my 04 continues.
After more than $10k in repairs, upgrades and everything else. I still can't catch a break.
Last week my wife drove the truck from California to Phoenix. Ran fine for 413 of the 414 mile trip. Truck stopped with symptoms of no fuel delivery less than a half mile from the house. After letting it sit for 20 minutes, it limped in to the house long enough to get parked. Replaced the fuel filters (including the Air Dog filters that probably didnt need it) still no start. FICM voltage is good. Tried the ICP disconnect trick. Nothing.
Not showing any codes on my SCT tunner. But that doesnt mean much. What next.
Two questions:
1) Anyone have a recommendation for a diesel shop in the Phoenix area? New to the area
2) Anyone want to buy a 04?
Old Jun 29, 2012 | 09:10 AM
2006powerstroke90's Avatar
2006powerstroke90
I got $500 and a trailer I'll come pick it up with my duramax
Sorry about your bad luck.
You need to check your ICP vs IPR %
Could be something as simple as a gummed up ipr from any dirt or crap getting into the oil with all the work that was just done.
Happened to me after doing my headstuds in my old 6.0
Old Jun 29, 2012 | 10:34 AM
steelhead2's Avatar
steelhead2
What kind of repairs were done to it?.after 10k it should about drive itself for you. Can you check fuel pressure?.
Old Jun 29, 2012 | 12:31 PM
3KB's Avatar
3KB
Update:
Ok, so I reattached the ICP and put everything back together and was about to call the tow truck and i jumped in and tried it. Struggled to life but is running strong now.
After you change out the filters, how long before you should get fuel all back through everything? I bet i had cranked on it 30 times while trouble shooting.
As for what repairs i have done. Most of the repairs/upgrades are in my signature. But I have had 6 of 8 injectors replaced at one time or another. 5 went when the FICM was weak. And one more was replaced while still in warranty from the shop.
I am developing the theory that it may be the injector wiring harness. With taking the ficm out and reinstalling it (twice) and disconnecting the ICP and reconnecting it. Is it possible?
A friend gave a wiring harness off an 07 6.0 when he did a cummins swap. Is it compatible?
Frustrated.
Old Jun 29, 2012 | 04:18 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Originally Posted by 2006powerstroke90
I got $500 and a trailer I'll come pick it up with my Duramax .......
. Lol
Old Jun 29, 2012 | 07:12 PM
steelhead2's Avatar
steelhead2
Should only take 3 key on-off cycles to get the air out of the fuel system. If you can check your fuel pressure, if you cant have it checked.
Old Jun 29, 2012 | 08:31 PM
Fulthrotl's Avatar
Fulthrotl
Originally Posted by 3KB
Two questions:
well, this is pretty obvious....
BPD
134 East Broadway Road | Mesa, Arizona 85210 | Tel 480.247.2331 | Fax 480.890.9777 | Toll Free 888.967.6653 | email: sales@BulletProofDiesel.com
Old Jun 29, 2012 | 08:46 PM
bismic's Avatar
bismic
Originally Posted by Fulthrotl
BPD
+1 .
Old Jun 29, 2012 | 10:48 PM
BLADE35's Avatar
BLADE35
I got $500
I got 501.00$$$ LOL
You need some gauges if you want to play
Gauges are a Must even if you take it to a shop for repair IMO!!!!
Looks like you have a Great shop close
Im shure you could get the Injector harness to work being it came off an 07
But if your ICP is in the Passenger valve cover its a direct fit
ICP under turbo then might have to unwrap the harness and relocate the ICP sensor
See if it starts fine XCold but has hard time HOT means HPO Problem
Old Jun 30, 2012 | 10:31 AM
3KB's Avatar
3KB
BPD
Didnt know BPD also had a shop. I know their products as I have helped a guy install their EGR and Oil cooler.
I will look into more gauges. It is running great right now. Did a 50 mile loop. Multiple stops and starts. 115 degree weather. No hot start issues.
Old Jun 30, 2012 | 10:35 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Use ScanGauge II .... best bang for the buck.
TooTall88
Jan 11, 2015 11:19 AM
Totally Tuna
Oct 14, 2011 11:45 PM
bulla
28
Jul 12, 2011 09:42 PM
cabinman
Aug 30, 2009 09:39 PM
hotrodw30
Aug 19, 2009 06:31 AM
